  • 1.  Centralized Licensing questions for 6.3
    Posted Jun 19, 2013 12:40 AM
    Just trying to make sure before I license the wrong controller...
    Already have 16 controllers, master/local setup with master redundancy.....licenses installed old fashioned way, each controller getting its own set.
    I have two brand new 7210 controllers and I bought 64 licenses for each one....
    SO.....
    I should install the licenses on the master licensing server.....and then the controllers will pull as many as they need?  Meaning those 128 AP license count could get splt up 5 here, and 15 over there, and another 2 over there, and 80 over there?
    OR
    If I use 1 ap on the controller it assumes the entire 64 ap license?
    #7210
  • 2.  RE: Centralized Licensing questions for 6.3
    Posted Jun 19, 2013 01:22 AM
    This is the way it will work
  • 3.  RE: Centralized Licensing questions for 6.3
    Posted Jun 19, 2013 02:13 AM
    That's what I thought and after reading your post I tested it out and WOW!
    Now I have more unused AP licenses than I know what to do with......
