certificate for 7005 web server in 8.6 - port 8082 needs cert?
  • 1.  certificate for 7005 web server in 8.6 - port 8082 needs cert?
    Posted Jun 29, 2022 07:35 PM
    I have a number of 7005s and I needed to install a security cert to the 443/4343 web service. That went fine.
    When performing a vulnerability scan the 443/4343 cert is fine, but I see that port 8082 has the default self-signed cert. I need to either upload or attach the good certificate to port 8082, or I need to put in a filter.
    I could do a firewall cp filter, but my vMM won't let me add or delete cp firewall entries. So "attaching" the good cert to this port is what I need to do.
    Any thoughts?
    Ambi
    Ambidexter
  • 2.  RE: certificate for 7005 web server in 8.6 - port 8082 needs cert?
    Posted Jul 08, 2022 09:31 AM
    Try adding the same certificate you used for the web interface as a captive portal certificate. This should resolve the issue.
