  • 1.  Certificates
    Posted Jul 10, 2023 12:51 PM
    All,
    I have tried to research this issue, but have not been successful.  If possible, could someone please explain where the certs that we have generated need to be installed.
    Example:  I have 2 Mobility Masters (MM1 and MM2) and I have 2 controllers under my Managed Network (MC1 and MC2).  I create a CSR and once I receive the validated certificates back (base64 and a pkcs7) where do I install each certificate.
    Any help will be appreciated.
    v/r
    Ruth
  • 2.  RE: Certificates
    Posted Jul 10, 2023 05:52 PM
    Are the certificates for Captive Portal?
  • 3.  RE: Certificates
    Posted Jul 10, 2023 09:25 PM
    Yeah what's the point of these certificates?  Or MM SSH?  MM HTTPS? ClearPass captive portal?  Certificate for local web direct on MM?  Something else?
  • 4.  RE: Certificates
    Posted Jul 11, 2023 09:11 AM
    No, I don't believe so
  • 5.  RE: Certificates
    Posted Jul 11, 2023 05:25 AM
    You could have a look at this Aruba Solution Exchange Article, which describes how to create (with OpenSSL) and install certificates on Controller/MM.
    In step 'Install' you can select controller/mm in order to get the right menu items to install the certificate.
