Check
this blog. It's old but still accurate. The recommendation is to use a private PKI for your RADIUS server certificates, as, you have noticed, automatic trust is not working anyway with a public RADIUS cert.
Original Message:
Sent: Jun 03, 2021 02:17 PM
Subject: Certificates, Android 11
With Android 11 and update coming out Android devices will loose the ability to trust/ignore a certificate, I'm sure Apple will follow close behind. Our clearpass server has a valid public cert and our radius server does as well. why won't the devices trust the cert?
Gary Naeger
