Changing mgmt IP addresses in Mobility Conductor pair
  • 1.  Changing mgmt IP addresses in Mobility Conductor pair
    Posted Mar 19, 2025 07:43 PM
    I have a virtual Mobility Conductor pair running in a productive environment, Conductor Redundancy configured using the VLAN100 interface, VRRP IP address created using the VLAN100 interfaces, Managed Devices connected using the VRRP address on VLAN100. In addition, the dedicated mgmt port is configured ("interface mgmt" in running configuration), it is plugged into the dedicated management network, through this port the webgui/cli management of the conductors is available. In addition there is an Airwave system which also has an IP address from the dedicated management network, the Airwave server is configured in the MDs by the dedicated mgmt IP address.
    Situation: we need to change network addresses in the dedicated management network on both Conductors and Airwave. Is this possible for a productive network? What do we need to pay attention to, what problems can we encounter?
    System is running AOS 8.10 version.
    Thanks for your help!
    The S in IOT stands for Security.
  • 2.  RE: Changing mgmt IP addresses in Mobility Conductor pair
    Posted Mar 20, 2025 12:34 AM
    The management interfaces should have nothing to do with any production process on the MCR, as all communication between MCR and MD is through the VIP.
    Honestly, I'd kill the management network usage, it serves almost no purpose that can't be as easily addressed otherwise.
    Carson Hulcher, ACEX#110
