SD-WAN
  • 1.  Changing the WAN MTU on a Microbranch
    Posted Apr 26, 2024 10:00 AM
    I am suspecting that the MTU settings of my microbranch are incorrect due to poor performance and retransmits. I am using a Verizon FWA device which should be configured with MTU 1400 or max 1428. How can I change the MTU setting on the microbranch to reflect this setting?
    TY
    Martijn van Overbeek
    Architect, Netcraftsmen a BlueAlly Company
  • 2.  RE: Changing the WAN MTU on a Microbranch
    Posted Apr 26, 2024 08:53 PM
    I dont think you can change the MTU for a IPSEC tunnel or for an uplink?
    the physical eth port has MTU=1500 and LTE has MTU=1300.
    Also the IPSEC tunnel have MTU = 1230
    is this for a
  • 3.  RE: Changing the WAN MTU on a Microbranch
    Posted May 02, 2024 05:00 PM
    Thanks for clarifying
