  • 1.  Channel width settings
    Posted Oct 23, 2014 05:14 PM
    We have the default-a radio profile set to 20MHz channels but I see 80MHz connections. Does the ssid profile override the radio profile?
  • 2.  RE: Channel width settings
    Posted Oct 23, 2014 05:28 PM
    What type of APs are you using ?
  • 3.  RE: Channel width settings
    Posted Oct 23, 2014 05:30 PM
    AP-224
  • 4.  RE: Channel width settings
    Posted Oct 23, 2014 05:35 PM
    do you have high-throughput enabled?
  • 5.  RE: Channel width settings
    Posted Oct 23, 2014 05:39 PM
  • 6.  RE: Channel width settings
    Posted Oct 23, 2014 05:44 PM
    Before you turn 80 MHz on you need make sure you do a proper channel planning with DFS channels enabled otherwise you will only have Two 80 MHz channels to work with .
    To start you could enable 40 MHz channels under the SSIDs profile > HT settings
  • 7.  RE: Channel width settings
    Posted Oct 23, 2014 05:55 PM
    I posted my settings -- not sure if you could view them. Both HT and VHT are enabled, channel width is 20MHz. I don't want 80MHz channels enabled because of density. Airwave seems to show 80MHz connections and the output of 'show ap detail ap-name' isn't clear:
    AP "ana_W104B_3ece" Radio 0 Operating Information
    Item Value Source
    Very High throughput Enabled Configuration
    Mode AP Configuration
    Band 802.11a
    Primary Channel 36 ARM
    80MHz Channel Group 36-48 ARM
    EIRP 18 ARM
  • 8.  RE: Channel width settings
    Posted Oct 23, 2014 06:26 PM
    If you do a show ap arm rf-summary ap-name you can see channel assignment or show so active if it's using 42E means is using 80 if it's using 40 then you will see 46-/+
    You can disable 80 in the radio profile
  • 9.  RE: Channel width settings
    Posted Oct 23, 2014 06:27 PM
    Also you should leave VHT enable that's how it accepts 802.11n associations
  • 10.  RE: Channel width settings
    Posted Oct 24, 2014 04:32 PM
    I would like to disable 80MHz channels. I thought having the radio profile set to 20MHz channel width would do that, but it appears like I'm seeing 80MHz connections both in Airwave and on the controller. 80MHz is enabled on the ssids but I would think the radio profile would not allow that.
  • 11.  RE: Channel width settings
    Posted Oct 24, 2014 04:44 PM
  • 12.  RE: Channel width settings
    Posted Oct 24, 2014 04:51 PM
    So it looks like the ssid profile overrides the radio profile? That's an odd design feature. Thanks for your help.
