I configure on hp5130b switch from the stp
conf:
stp mode mstp
stp region-configuration
region-name
revision-level 1
instance 1 vlan 1 to 199
instance 2 vlan 200 to 399
active region-configuration
stp instance 0 to 3 priority 12288
stp bpdu-protection
loopback-detection interval-time 5
shutdown-interval 0
interface range GigabitEthernet 1/0/1 to GigabitEthernet 1/0/48
stp edged-port
stp global enable
to check if a port and block I use the command:
display stp down-port
I wanted to know if with my centreon-plugin monitoring tool if it was possible to check the interface block ?
thank you
#checkinterface#centreon-plugin#STP#spanning-tree
