  • 1.  Cisco dACL on 9800 Wireless controller
    Posted Sep 23, 2024 12:26 PM
    Edited by MT9 Sep 23, 2024 12:51 PM
    Hey,
    I'm trying to get dACLs working on my wireless controller. We are running 17.12 on the controller and 6.11.1 on Clearpass. So there is support on the WLC for dACLs and we're in a local centralized mode for the APs. I'm trying a very simple permit ip any any in a dACL. On the WLC, I am ending up with an ACL failure. In the trace logs, this seemed to be the most relevant line
    2024/09/23 11:48:56.237777662 {wncd_x_R0-3}{2}: [errmsg] [20775]: (note): %SESSION_MGR-5-FAIL: R0/3: wncd: Authorization failed or unapplied for client (fa44.d8c8.7fe3) on Interface capwap_90c0008b AuditSessionID 14017C0A0000F20E1F925165. Failure Reason: ACL Failure. Failed attribute name xACSACLx-IP-dACL_Allow_All-3036-4.
    In the clearpass debug logs, it seems that it's sending the proper CiscoSecure-Defined-ACL AVPair, but then I get an error at the end
    2024-09-23 12:44:39,339 [RequestHandler-1-0x7fd201dee700 r=R0000002c-03-66f19af7 h=1137] ERROR Core.MacAuthSessionQueryEventHandler - Failed to get MacAuth session info for fa44d8c87fe3
    So to me it doesn't like something about the ACL or perhaps there's an insight issue?. I tried sending a VLAN enforcement profile along with it thinking maybe it needs some additional session context information to fill out the user role on the WLC.
    Has anyone done this? Any suggestions?.
    Thanks.
  • 2.  RE: Cisco dACL on 9800 Wireless controller
    Posted Sep 24, 2024 10:48 AM
    In order to not be https://xkcd.com/979/ I will post the solution
    The issue was that the AAA Authorization method list on the 9800 must have default configured with the server group pointing to the RADIUS servers. You must either use the default or pass back the name of the method list in an AV-Pair as part of the access accept. Now it works as expected.
  • 3.  RE: Cisco dACL on 9800 Wireless controller
    Posted Sep 24, 2024 11:12 AM
    Can you post your exact ACL syntax here?
  • 4.  RE: Cisco dACL on 9800 Wireless controller
    Posted Sep 24, 2024 11:27 AM
    The ACL under dACL was just permit ip any any
    Once you send the authorization method list as an AV-Pair everything works.
