Hi community,
This is an excerpt of the "AirWave 8.2.7 Supported Infrastructure Devices" document:
According to this, I see you can get a lot of info from third-party vendor devices. Does this info refer only to the devices included within the "Third-Party Vendor Devices" section? Because I have also seen other posts about this which says that for the devices which are not in the list, you can only get up/down status and some interface metrics, not more. For example:
https://community.arubanetworks.com/t5/Network-Management/How-to-add-Ruckus-AP-s-to-Airwave/td-p/274266
Attached the "AirWave 8.2.7 Supported Infrastructure Devices" document. My customer has APs Fortinet and Ruckus, so I guess I will only get up/down status and maybe interface metrics from them, but I will not be able to do configuration, firmware upgrades, see traffic applications, etc.
Can you confirm please?
Many thanks in advance,
Julián
