Wired Intelligent Edge
  • 1.  class ipv4
    Posted Mar 21, 2024 04:44 AM
    Hi
    I have basic roles on our 5400R switches sent from clearpass with a simple policy such as:
    policy user "PERMIT-ALL"
         10 class ipv4 "IP-ANY-ANY" action permit
    I would to see if I can expand that to create a network isolation type policy, let certain ip addresses through and block the rest.   I am unsure on how to program this.
    Is there a guide or example I can follow - I haven't seen much information on it over the web so far.
  • 2.  RE: class ipv4
    Posted Mar 21, 2024 12:19 PM
    Here is a video (a little age but still accurate) from the Airheads Channel: AOS User Roles
    But the config would likely look like something below:
    class ipv4 "ALL"
    1 match tcp any any
    exit
    class ipv4 "InternalDHCP"
    1 match udp any any eq 67
    exit
    class ipv4 "InternalDNS"
    1 match tcp any host 10.211.102.100 eq 53
    2 match udp any host 10.211.102.100 eq 53
    3 match tcp any host 10.125.105.100 eq 53
    4 match udp any host 10.125.105.100 eq 53
    exit
    class ipv4 "InternalLAN"
    1 match ip any 10.0.0.0/8
    exit
    policy user "Guest-Device-EW"
    1 class ipv4 "InternalDNS" action permit
    2 class ipv4 "InternalDHCP" action permit
    3 class ipv4 "InternalLAN" action deny
    10 class ipv4 "ALL" action permit
    exit
    aaa authorization user-role name "Guest-Device" policy "Guest-Device-EW"
    exit
    If my post was useful, please Accept Solution and Give Kudos.
    Zak Chalupka
    Principal Engineer - HPE Aruba
    ACDX | ACMP | ACSP | ACCP
    wifizak@hpe.com
    Ideas expressed here are solely my own and not necessarily that of HPE Aruba.
