  • 1.  clear pass quarantine hang
    Posted 23 days ago
    Edited by andrea.armellini 23 days ago
    Hello!
    In my business network, ClearPass is currently configured only for Wi-Fi connections (802.1X is not yet implemented for wired connections). I'm facing a persistent issue that I haven't been able to resolve.
    Wi-Fi (Aruba wifi with Aruba 7030 controllers) is configured using TEAP with both machine and user certificates, and devices are joined to the AD domain. When a Windows PC boots up, machine authentication completes, and the device enters quarantine before user login. After the user logs in, user authentication should occur and complete successfully.
    However, quite often some users get stuck after entering their credentials. In ClearPass, I can only see the machine authentication-there's no trace of the user authentication. If I plug the notebook into a wired connection (without 802.1X on the LAN), the login completes, the Windows desktop loads, and user authentication appears in ClearPass logs.
    Users experiencing this issue often use Windows Hello for Business for authentication.
    I've tried adding all domain controllers, the Entra Connect server, and both root and intermediate CAs to the quarantine bypass list. I add svc-kerberos service, svc-dns.... but nothing seems to help.
    Do you have suggestions?
    thank you
  • 2.  RE: clear pass quarantine hang
    Posted 23 days ago
    Edited by vigan 23 days ago
    Hi Andrea,
    In a comparable TEAP rollout we traced intermittent user-authentication failures back to certificate auto-enrollment. Machine auth completed, but Windows had no user certificate to present because some AD groups lacked the required auto-enroll permissions on the PKI template.
    It may be worth confirming that:
    every security group referenced by your network-access policies has at least Read and Enroll (preferably Autoenroll) rights on the user-auth certificate template;
    the Certificate Services Client – Auto-Enrollment GPO setting is enabled for both Computer and User configurations and applies to all OUs that hold user accounts.
    A quick workstation check (certutil -pulse or gpupdate /force) followed by a look for Event ID 6 in the Application log will show whether a user cert is issued. If it isn’t, inspect the user’s group memberships and the template ACLs.
    Aligning auto-enrollment permissions across all relevant AD groups resolved the problem in our environment—user certificates issued automatically and TEAP moved cleanly from the machine to the user phase.
    If you need the exact template ACL we used, let me know.
    Best regards,
    Vigan
  • 3.  RE: clear pass quarantine hang
    Posted 23 days ago
    Hello Vigan
    Thank you for you answer
    In Aruba controller, in quarantine role I enabled svc-dhcp service with the help of Aruba support during a ticket resolution; I enabled also svc-dns and svc-kerberos with all ip of domain controller CA and authentications server
    Is there other service that I need to permit?
    Andrea Armellini
    Campagnolo Srl
    Via della Chimica n°4, 36100 Vicenza
    T. +39 0444 225 500
    FACEBOOK | INSTAGRAM | CAMPAGNOLO.COM
    Shamal
    * Email Privacy Information
  • 4.  RE: clear pass quarantine hang
    Posted 23 days ago
    Hi Andrea,
    The quarantine ACL appears correctly defined; it mirrors the dynamic ACL approach we apply on wired ports until user authentication succeeds.
    Please now verify user-certificate auto-enrolment for every Active Directory security group authorized for TEAP:
    1. Log on to an affected workstation and open certmgr.msc. Under Personal → Certificates, confirm that a certificate issued from the designated user-authentication template is present.
    2. If the certificate is absent, ensure each relevant security group has Read, Enroll, and Autoenroll permissions on that template.
    3. Confirm that the Certificate Services Client – Auto-Enrollment GPO is enabled for users and scoped to the OUs containing those groups.
    After checking for this, a gpupdate /force  on the client should do the trick for the users to get a user certificate from the CA.
    Vigan
  • 5.  RE: clear pass quarantine hang
    Posted 18 days ago
    Today a user with the issue :(
    The machine and user certificate are already in the user pc. The certificate was created yesterday
    In the clearpass log TeapMethod 1 EAP-TLS complete with success, it get machine name from the machine certificate. Teap-Method-2-Status Failure, with empty username.
    This is correct while user is on login screen before insert credentials. Once user insert credentials, windows stuck on welcome screen, and I can't see clearpass log.
    In controllers, the quarantine role permit access to CA, intermediate CA, DCs, service dns, kerberos ldp and ldps port on the entire network.
    User stucks for about 20 minutes, than he connect to wired cable: clearpass log TEAP method 2, he get the desktop and wifi connection....
    I don't know what else to look at: I would have to get between the PC and the network and understand what it is trying to do
  • 6.  RE: clear pass quarantine hang
    Posted 18 days ago
    Hi Andrea,
    Since the certificates are already in place, how is the wifi authentication profile configured on the NIC.
    Are you using both user or computer authentication, or just computer authentication?
    You can also double check this EAP-TEAP tech note from HPE for reference MAYBE you might have missed something on the WIFI side.
    https://arubanetworking.hpe.com/techdocs/NAC/tech-corner/teap/
    Hope this might help :).
    Cheers,
    Vigan
  • 7.  RE: clear pass quarantine hang
    Posted 16 days ago
    Edited by andrea.armellini 16 days ago
    My doubt is that the issue come with windows hello for business, where user call Azure AD and Kerberos Server Key like this schema. In quarantine role pc obtains the dhcp and vlan is trusted to internet. Azure AD should be trusted without user auth in my firewall, so up to now I have always ruled out that it was a navigation problem....i have to go in deep here.
    Yesterday I had another pc with issue: user was trying with finger print and login stuck at welcome screen. I ask him to insert active directory password (not windows hello Pin) and he got desktop immediately
  • 8.  RE: clear pass quarantine hang
    Posted 16 days ago
    Azure Active Directory (Azure AD) cannot be used as a direct authentication source for EAP-based methods such as EAP-TLS or EAP-TEAP in Aruba ClearPass. This is because Azure AD does not support legacy protocols like RADIUS or LDAP, which are required during the 802.1X authentication handshake.
    This is confirmed in Aruba's official documentation, which states that the Azure AD authentication source in ClearPass is only used for authorization purposes, after a successful authentication event such as certificate-based EAP-TLS. ClearPass queries Azure AD (via the Microsoft Graph API) to retrieve user attributes like group membership for policy enforcement:
    https://arubanetworking.hpe.com/techdocs/ClearPass/6.11/PolicyManager/Content/CPPM_UserGuide/Auth/AuthSource_Azure.htm
    If direct authentication against cloud identities is required, you must deploy(if you haven't already) Azure AD Domain Services (AAD DS). AAD DS provides LDAP and Kerberos support, which allows systems like ClearPass to perform traditional authentication workflows:
    🔗 https://learn.microsoft.com/en-us/azure/active-directory-domain-services/overview
    The recommended and supported model by both Aruba and Microsoft is to use certificate-based authentication (EAP-TLS or TEAP) combined with Intune and NDES/SCEP to provision certificates to Azure AD-joined devices:
    https://learn.microsoft.com/en-us/mem/intune/protect/certificates-profile-scep
    In this model, ClearPass handles certificate validation during authentication, and Azure AD provides authorization context afterwards.
  • 9.  RE: clear pass quarantine hang
    Posted 16 days ago
    I am in an hybrid join scenario. I had to deploy Azure Ad Kerberos that create a new object in my domain controller OU, to get windows hello for business working. I understand it works like a proxy for Azure AD, so I really don't know if this create conflict with radius authentication.
    I have to study better our configuration
