  • 1.  CLEARPASS 6.11 - EAP-TEAP authentication against Entra ID - Is it possible?
    Posted Apr 20, 2024 01:47 PM
    We are in the process of upgrading from PEAP to TLS (prefer TEAP) on our wireless network.  My understanding is that CP 6.11 currently only supports user authentication against Entra ID.  So, is it possible to do TEAP authentication against Entra ID?  If so, how?  Thanks.
  • 2.  RE: CLEARPASS 6.11 - EAP-TEAP authentication against Entra ID - Is it possible?
    Posted Apr 21, 2024 03:57 PM
    FAIK
    ClearPass can interact with Azure to retrieve user group details and perform policy enforcement. This source is only capable of authorization, not authentication.
    Azure (arubanetworks.com)
    Marcel Koedijk | MVP Expert 2023 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
  • 3.  RE: CLEARPASS 6.11 - EAP-TEAP authentication against Entra ID - Is it possible?
    Posted Apr 21, 2024 07:13 PM
    Hi.  My understanding is that 6.11 only support Entra ID user authentication - utilizing the userPrincipalName from the client cert - to retrieve user group information for role mapping and subsequently policy enforcement.
  • 4.  RE: CLEARPASS 6.11 - EAP-TEAP authentication against Entra ID - Is it possible?
    Posted Apr 22, 2024 09:20 AM
    Not users, no. You can authenticate devices if you use the Intune Extension to sync devices and use the Endpoint Database to authenticate.
