Initially, we are planning to enable wired dot1x authentication on the wired environment through group policy and in the next phase will deploy OnGuard.
Here the problem is there is no segmentation between Floor side endpoints and Datacenter machines in the active directory. If we push the settings through Group policy it may apply on Datacenter Machines also.
1. Can we enable dot1x settings (not authentication) on datacenter machines (Server & Virtual machines)
2. What is the best method for deploying dot1x+ Onguard? i.e. Group policy and install Onguard agent. or using Quick connect.
3. Is license required for Quickconnect as we already have 10000 access and 5000 OnGuard Perpetual licenses.
Please suggest.
Yugandhar
