  • 1.  Clearpass Active Profiling Issue
    Posted Nov 06, 2022 03:51 AM
    Dear Community,
    I have some OT devices in the Network need to Profile then Before apply any actions. So i add NAD devices and configure SNMP v3 and enable "Read ARP table from this device" Switches are Cisco, After the Configuration I am getting this error in event viewer.
    Tharindu Pamoda
  • 2.  RE: Clearpass Active Profiling Issue
    Posted Nov 07, 2022 01:02 AM
    Can you packet capture the SNMP flow or check the Cisco switch logs? It looks like maybe your SNMP credentials might be incorrect or a firewall might be stopping the response.
