You can verify if there is accounting information in Access Tracker. If there is, you should see a tab labeled Accounting:
If you don't see that, check in your controller, firewalls in between, why accounting information is not reaching ClearPass.
Original Message:
Sent: Sep 21, 2022 06:46 AM
Subject: ClearPass Active Sessions for Guest users
Thank you!
Kind Regards,
Peter Abene | Wireless LAN Network Engineer
o +1 732-812-8339 • m +1 973-975-7961 peter.abene@vonage.com
23 Main St. • Holmdel, NJ 07733 • USA
Original Message:
Sent: 9/21/2022 4:37:00 AM
Subject: RE: ClearPass Active Sessions for Guest users
here is the screenshot for it
Original Message:
Sent: Sep 21, 2022 04:27 AM
on the AAA profile that is in use under the authentication menu, specify a radius accounting server and if you want to receive more details about usage, you will need to enable AAA interim accounting on the aaa profile
Thomas
Original Message:
Sent: Sep 21, 2022 04:14 AM
Thank you. I will do that. Do you know where on the controller I enable RADIUS accounting?
Kind Regards,
Original Message:
Sent: 9/21/2022 3:28:00 AM
in addition on ClearPass (each server in the cluster) you will need to go to the server configuration => Service Parameters => Radius Server in dropdown => change Accounting from false to true (False is the default)
Thomas
Original Message:
Sent: Sep 20, 2022 10:37 AM
On your NAD (controller, switch, etc.) you need to enable RADIUS accounting - pointing to the server group that contains ClearPass
ACNSA | ACEA | ACCP | ACMP
Original Message:
Sent: Sep 20, 2022 10:17 AM
I did enable Insight.
Where do I configure accounting?
Original Message:
Sent: 9/20/2022 9:12:00 AM
Do you have accounting configured? And enabled Insight on your ClearPass node?
Original Message:
Sent: Sep 19, 2022 11:00 AM
Any reason I do not see any guest sessions under "Active Sessions" in ClearPass?
Peter
