  • 1.  Clearpass and Alliet Telesis switches TACACS+
    Posted Aug 29, 2024 05:39 AM
    Hello Airheads,
    I was wondering if anyone had experience in configuring TACACS+ Service for Allied Telesis switches.
    I configured the enforcement profile with priv-lvl=15 but i get the following error in the access-tracker
    Maybe some attribute is missing in the returned enforcement.
    I hope somebody can help.
    Many thanks
    Ale
  • 2.  RE: Clearpass and Alliet Telesis switches TACACS+
    Posted Aug 29, 2024 05:58 AM
    Hi
    I don't have experience of Allied Telesis switches, but you problem is related to the configuration in ClearPass.
    In most cases when I have seen this the enforcement profile have been limited to a specific Network Device Group.
    Make sure that the switch is included in any Device groups specified or remove the Device Group condition if it can be done without interference in other rules.
    Maybe a copy of the current profile can be good to test with.
    Best Regards
    Jonas Hammarbäck
    Aranya AB
  • 3.  RE: Clearpass and Alliet Telesis switches TACACS+
    Posted Aug 30, 2024 02:54 AM
    Hi jonas and thank you,
    there is no device group list configuration on th enforcement profile.
    I copied this profile from one that is working for cisco switches.
    I was thinking about some missing attribute in the access-accecpt that lets the switch fail the authorization for the session. That's why I am looking for someone who already had experience with Allied Telesis Products.
    Thank you and kind regards
    Ale
  • 4.  RE: Clearpass and Alliet Telesis switches TACACS+
    Posted Aug 30, 2024 03:03 AM
    But the error message clearly indicates that ClearPass can't apply any of the enforcement profiles in the enforcement policy.
    Create a new TACACS enforcment from scratch with the basic settings and see how this works.
    Can you share the configuration of the enforcement policy, the enforcement profile and also the output from the Summary tab in Access Tracker?
    Best Regards
    Jonas Hammarbäck
    Aranya AB
  • 5.  RE: Clearpass and Alliet Telesis switches TACACS+
    Posted Aug 30, 2024 04:51 AM
    Also check whether unmatched commands are permitted in the enforcement profile or whether an allow list exists.
    Waldemar
    ACCX # 1377, ACEP, ACX - Network Security
  • 6.  RE: Clearpass and Alliet Telesis switches TACACS+
    Posted Aug 30, 2024 04:56 AM
    yes it is:
    Thank you
    Kind Regards
  • 7.  RE: Clearpass and Alliet Telesis switches TACACS+
    Posted Aug 30, 2024 05:08 AM
    here you go with access tracker session details:
    Enforcement Policy Config:
    and enforcement profile:
    Thank you so much
    kind regards
    Ale
