Clearpass and Chrome 58
  • 1.  Clearpass and Chrome 58
    Posted Apr 20, 2017 04:08 PM
    Anyone experienced this yet?
    Since updating to Chrome 58, Clearpass Policy Manager GUI is no longer accessible.  Only top screen header loads. [edit] CPPM version 6.6.5.93247
    Developer mode says that dojo.js:16 [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
    On Guard / Guest, and Insight still work however.
    [edit #2] I found that if you resize the window, the page finishes loading.
  • 2.  RE: Clearpass and Chrome 58
    Posted Apr 20, 2017 04:46 PM
    I have not seen that in Chrome 58. Best to open up a TAC case.
  • 3.  RE: Clearpass and Chrome 58
    Posted Apr 21, 2017 01:57 PM
    Ah, thanks for the "resize" hint. I'd opened it in Firefox before I thought of that. We are still on version 6.5.7.85381, so it is not a recent change in CPPM that breaks it.
  • 4.  RE: Clearpass and Chrome 58
    Posted Apr 24, 2017 05:43 PM
    Just started seeing the same behavior here with Chrome 58. No issues with Firefox 53. Thanks for the workaround.
  • 5.  RE: Clearpass and Chrome 58
    Posted Apr 24, 2017 07:17 PM
    Yup.  Seems to be a javascript issue.  I couldn't even hit the login button here to post.  Had to disable and reenable javascript on Chrome 58.  Then do the resize trick.
  • 6.  RE: Clearpass and Chrome 58
    Posted Apr 25, 2017 05:46 PM
    Just a quick update. Engineering is aware of the issue with a change by Google in Chrome 58. I will post updates here.
  • 7.  RE: Clearpass and Chrome 58
    Posted Apr 26, 2017 01:47 PM
    Thanks for confirming. I was awfully suspicious of the Chrome update.
    Hopefully it will be a quick fix. Until then, resize away!
  • 8.  RE: Clearpass and Chrome 58
    Posted May 01, 2017 06:06 PM
    Tim,
    Do you have an update on this yet?
  • 9.  RE: Clearpass and Chrome 58
    Posted May 01, 2017 06:08 PM
    Nothing to report yet. The quick workaround is to briefly resize the browser.
  • 10.  RE: Clearpass and Chrome 58
    Posted May 19, 2017 08:02 AM
    The issue is found and is supposed to be fixed in the upcoming 6.6.7 ClearPass patch release.
    For the time till then, a nice tip I got from Garth Benedict: use the zoom keyboard shortcuts: Ctrl -, Ctrl = to quickly zoom out and in again to get around this issue. I posted a short video demo on Youtube:
  • 11.  RE: Clearpass and Chrome 58
    Posted Jul 10, 2017 10:13 AM
    I just updated to 6.6.7.96909 and can confirm that the issue has been fixed.
  • 12.  RE: Clearpass and Chrome 58
    Posted Jul 10, 2017 10:22 AM
    Thanks for letting know. Same here after the upgrade.
  • 13.  RE: Clearpass and Chrome 58
    Posted Jul 27, 2017 04:29 PM
    Patch 7 (6.6.7 plus hotfix) fixed the issue for me.
