  • 1.  ClearPass and Cisco WLC - guest portal with sponsor approval
    Posted Sep 29, 2024 08:09 PM
    Is ClearPass usabe for doing "guest portal with sponsor approval" simultaneusly to Aruba and Cisco wireless systems? If the answer is yes, is the same appliance used for the two systems at the same time? We have Cisco and Aruba wireless system also, and now we would like to make our guest network to "sponsor approval" type. We bought ClearPass with some entry license and I need to know should we also buy Cisco ISE, or not?
    Thanks!
    The S in IOT stands for Security.
  • 2.  RE: ClearPass and Cisco WLC - guest portal with sponsor approval
    Posted Sep 30, 2024 09:17 AM
    Yes. You would build two seperate self-registrations typically. You send back the weblogin info differently for Aruba and Cisco. For instance, on Aruba you send back the weblogin to your controllers via "securelogin.arubanetworks.com" (or whatever you change this to with your certificates).
    In the advanced settings for the self-registrations you can check the box for sponsor approval being required.
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
  • 3.  RE: ClearPass and Cisco WLC - guest portal with sponsor approval
    Posted Sep 30, 2024 11:01 AM
    Yes
    Yes
    No, ISE is not needed.
