  • 1.  ClearPass and Govroam implementation
    Posted Aug 17, 2021 10:02 AM
    Is there some kind of deployment guide / information available on how to implement ClearPass to work together with GOVROAM?
    Any information regarding how to configure this is welcome.
    Thanks and best regards,
    Martin Verbon
    Martin Verbon
  • 2.  RE: ClearPass and Govroam implementation
    Posted Aug 18, 2021 03:40 AM
    Hi Martin
    Govroam works in a similar way to eduroam, here's the documentation for the service template for eduroam:
    https://www.arubanetworks.com/techdocs/ClearPass/6.10/PolicyManager/Content/CPPM_UserGuide/Services/ServiceTemplates_Eduroam.htm
  • 3.  RE: ClearPass and Govroam implementation
    Posted Aug 18, 2021 04:44 AM
    Hi nopenope,
    Yes, I used the template in my lab first and it looks indeed similar. So I will try that one and reconfigure the environment to work with govroam.
    Thx!
    Martin
    Martin Verbon
  • 4.  RE: ClearPass and Govroam implementation
    Posted Aug 19, 2021 04:08 AM
    I reconfigured all the components, services etc., to work with govroam.
    This was straight forward and should work in combination with govroam.
    I was not yet able to test it, but this should work fine.
    Best regards,
    Martin
    Martin Verbon
  • 5.  RE: ClearPass and Govroam implementation
    Posted Aug 20, 2021 06:44 AM
    There is a checkbox on the controller that needs setting to enable it to obey what clearpass is sending otherwise. It just uses what is the controller default
    Somewhere in the radius server definition on the controller
    Sent from my iPhone
