  • 1.  Clearpass Authentication using EAP-TEAP (EAP-Chaining) - username missing method 1
    Posted Oct 09, 2023 04:38 AM
    Could you help regarding eap-teap config on clearpass, the config works fine (chaining is ok) but i would like to see the machine hostname in the access tracker when the computer is on the login screen . For now i have to select which method i would see in the tracker, see below user (method2) is selected.
    when user is login , eveything is ok
    but when the computer is on the logon screen (username stay blank)
    is there any solution to seen the computer name from method 1 in the tracker ?
    thanks for your help
    Patrick.
  • 2.  RE: Clearpass Authentication using EAP-TEAP (EAP-Chaining) - username missing method 1
    Posted Oct 09, 2023 05:28 AM
    If you want to see the computer account (Method-1), select that in your TEAP Authentication method.
    For even further flexibility you can return the IETF:Username with the Authentication-TEAP-Method-1 or Authentication-TEAP-Method-2 or even another attribute or value during your enforcement. The IETF:Username, when returned in an Enforcement will override the sent username (generic) or the method-1 or 2 username (TEAP Method); and allow you for example to return the Computer (Method-1) name if the User (Method-2) fails; or the Username if computer auth fails.
  • 3.  RE: Clearpass Authentication using EAP-TEAP (EAP-Chaining) - username missing method 1
    Posted Oct 09, 2023 02:36 PM
    Thanks Herman , it's works , i have now the name of the computer in the tracker,
    another issue is that i cannot not verify the computer (teap method1) , i have no AD info in the input
    when i check with only eap-tls (machine authentication) i have well the correct info.
    any idea ?
    thanks for your help.
  • 4.  RE: Clearpass Authentication using EAP-TEAP (EAP-Chaining) - username missing method 1
    Posted Oct 10, 2023 04:47 AM
    You may duplicate your AD Authentication Source, and in there in the query change the Authentication:Username to Authentication:TEAP-Method-1-Username; or even have 2 auth sources under authorization one for computer and one for user authentication. In the end, these values are just the output of LDAP queries, which you can fully customize.
  • 5.  RE: Clearpass Authentication using EAP-TEAP (EAP-Chaining) - username missing method 1
    Posted Oct 10, 2023 07:47 AM
    tryed to duplicate AD source  with this filter:
    the username mention in the method 1 is :
    DESKTOP-K9VDJP3$
    but in the tracker is see "\" character is added in the username: so it's not match
    any idea why enforcement profiles send me "\" + computer name ?
    is it possible to remove the "\" in the filter ?
    regards.
  • 6.  RE: Clearpass Authentication using EAP-TEAP (EAP-Chaining) - username missing method 1
    Posted Oct 11, 2023 07:30 AM
    It's probably not really sending the \. In many programming languages, the $ is a special character and with \ it's 'escaped' to mean a literally $.
    What does the Alerts tab tell you?
    In your Authentication Source, is the BaseDN high enough to include OU=Computers, or whatever location you have your computer account stored?
    Moving to TLS would probably solve your issue as well as that removes the use of $ in the hostname and removes the vulnerability of using password authentication.
