If you can migrate the full disk including data in Azure, in a way the disk looks exactly the same for the Operating System (ClearPass), I don't see a big issue.
With ESXi, I know you can migrate virtual disks to another storage, which for the VM does not change how it's done. Can only assume you can do something similar in Azure.
Maybe asking Microsoft or Azure experts provides a better answer. And I would always be sure to have a backup before doing anything like this.
If you have urgent issues, always contact your HPE Aruba Networking partner, distributor, or Aruba TAC Support. Check
https://www.arubanetworks.com/support-services/contact-support/ for how to contact HPE Aruba Networking TAC. Any opinions expressed here are solely my own and not necessarily that of Hewlett Packard Enterprise or HPE Aruba Networking.
Original Message:
Sent: Feb 03, 2025 05:40 AM
Subject: ClearPass Azure Disk Change - Impact and Preparation
I have a question regarding ClearPass in Azure. During the initial configuration, I selected a Premium SSD LRS disk. Now, after two months, I want to change the disk to the Standard Storage type. Will this cause any operational issues with ClearPass? I don't want to take any risks with this change. I know ClearPass needs to be fully down before making the change, but is there anything else I need to prepare for before proceeding?
yaser
