You would do that similar to what you would do on-premises. Make sure that from the guest network the ClearPass is accessible on HTTPS, which you probably want to do through a VPN/connection between your site and your VPC/deployment in Azure.
If you have urgent issues, always contact your HPE Aruba Networking partner, distributor, or Aruba TAC Support. Check
https://www.arubanetworks.com/support-services/contact-support/ for how to contact HPE Aruba Networking TAC. Any opinions expressed here are solely my own and not necessarily that of Hewlett Packard Enterprise or HPE Aruba Networking.
Original Message:
Sent: Feb 17, 2025 11:57 AM
Subject: ClearPass Azure Hosted Inquiry
Thanks for the reply and details. Do you folks use it for Guest Wifi authentication, or how do you handle that aspect?
Thanks very much,
Original Message:
Sent: Feb 17, 2025 09:13 AM
We are having 2x ClearPass VMs in Azure and doing 802.1x authentication using EntraID and Intune. It is working fine although we have some EAP timeout packets but the end users don't notice any issues.
Original Message:
Sent: Feb 14, 2025 01:02 PM
Bit of an open ended question, but we currently have two CP servers on prem and are using for both wired and wireless 802.1x authentication and guest Wi-Fi access. We have started to look at hosting CP in Azure, but in some reading it sounds like we might not be able to support 802.1x. Can anyone shed any insight on moving to Azure along with maintaining the current deployment, or does it need some large scale changes?
Thanks very much,
