Hi
If you have sponsor approval you can add a drop down to the sponsor page whre the sponsor can select the correct time for the user.
In the Sponsor Confirmation section of the self registration page you can add the values to add to the dropdown
The result will be a dropdown like this in the sponsor confirmation page:
If you don't have sponsor approval, it's a bit more complicated, but one option could be to add this drop down on the registration form, but change the lable and text visible to the guest from expiration time to Account type or something similar and provide the options Guest and Consultant but set the value of the expiration time to 2 days respective 7 days.
Best Regards
Jonas Hammarbäck
Aranya AB
Original Message:
Sent: Oct 24, 2024 06:32 PM
Subject: ClearPass Captive Portal Help
Hello everyone, hope you are well.
I would like to know if there is a way to create a field to select concession time in the guest registration in the ClearPass captive portal.
I mean, a user arrives and I want to give that user 2 days of concession to the network.
But my other provider arrives and I want to give him 7 days.
What I want to achieve is that in the captive portal when he self-registers he can select or write the time he wants to stay in the network as in the previous examples and I accept him.
How could I achieve that? place that field inside the captive portal and make it work?
Thank you very much for your help in advance!
