Clearpass Captive Portal with External SQL Consult
  • 1.  Clearpass Captive Portal with External SQL Consult
    Posted May 07, 2018 10:22 AM
    Hi Community,
    We have a costumer that wants to configure their Clearpass in order to authenticate the costumers with an existing Costumer SQL database. The idea is to have a captive portal with an ID form only, if the ID is valid on the external DB the user can surf on the web, if it is not we need to provide a CP with self registration or facebook in order to update the external SQL DB and allow the costumer to surf on the Web.
    Do you have some tips in order to how create a single form Captive portal without password and validate it on an external DB ?
    Attached I have uploaded a flowchart of all the authentication process that the costumer wants to implement.
    Attachment(s)
    pdf
    Captive Portal Flow.pdf   63 KB 1 version
