Good to hear. Moving to an always accept on the MAC auth is a good thing anyways as moving to Enhanced Open may require the successful authentication in order to complete the four way handshake at device association.
Original Message:
Sent: Jan 22, 2025 07:53 AM
Subject: Clearpass / Cisco WLC / CoA
Seems like I got it working. Compared the working config for Juniper APs and found this thread confirming the mismatch: https://community.arubanetworks.com/discussion/radius-coa-webauth-policy#bmc58f27b4-23c6-4c7d-9020-348f5ad7c566
So now the CoA works every time.
Original Message:
Sent: Jan 15, 2025 05:31 AM
Someone else was hired for setting this up, so I'm not quite sure why the server-initiated were choosen over the controller-initiated. As mentioned its a setup with Cisco WLC and APs, so no Aruba/HP equipment other than Clearpass.
When it comes to the server-initiated method, we have that working flawlessly with Juniper APs. They use a cloud based controller (Mist) vs our Cisco that is on-prem. The guide used for setting up Juniper was this: https://www.mist.com/wp-content/uploads/Mist-Clearpass-Guest-1.pdf
Unfortunately I haven't found anything similar for Cisco.
Its the controller-initiated which is the recommended one then?
Original Message:
Sent: Jan 14, 2025 10:14 AM
The error is indicating that the cache doesn't contain any relevant information for the client device in order to issue the CoA.
Is there a specific reason you're using a CoA workflow rather than controller initiated and straight RADIUS auth?
Carson Hulcher, ACEX#110
Original Message:
Sent: Jan 13, 2025 09:08 AM
Hello.
I'm fairly new to Clearpass and Cisco WLC, so hopefully this is rather straight forward for you experts out there :) I've searched the discussion forum, but I havent managed to connect all the dots..
First an working example:
- Unknown device connects to the wlan and gets redirected to the Clearpass login-page.
- Authenticates with a valid account, Clearpass sends a CoA:
The user sees the 10 sec countdown and: - The device reconnects and have access to the network.
Detailed log attached CoA ok.txt.
This happens very rarely, 99% of the time the Webauth occours and the CoA is not sent. Then it looks like this:
- Authenticates with a valid account, Clearpass does not send a CoA:
- The device reconnects by itself after 5+ minutes and have access to the network.
Detailed log attached CoA not ok.txt
When the device is authenticated I can try all the different CoA from the change status tab:
They all work, so I guess that means the setup/flow between Clearpass and the Cisco WLC is working.
The only difference in the Webauth input between the two is:
Found under computed attributes for the working one.
In the detailed logs, the one not working has the following:
INFO Common.TagDefinitionCacheTable - No TagDefCacheMap could be found for instance id = 57625 entity id = 72
INFO Common.TagDefinitionCacheTable - Building the TagDefMapTable for Endpoint instance=57625
INFO Common.TagDefinitionCacheTable - Built 0 tag(s) for instanceId=57625|entityId=72|entityName=Endpoint
INFO TAT.TagAttrHolderBuilder - No tags built for instanceId=57625|entity=Endpoint
WARN Core.PETaskPostAuthEnfProfileBuilder - handleHttpResponseEv: Fetching Radius attributes from battery failed, errMsg=
The self-reg (login) page is setup like this:
We had help trying to set this up, so there has been some experimenting with Controller-initiated login method. I've tried changing from App Authentication to Local, same result.
Any input is much appreciated!
Regards
Joe
