CPPM is version 6.10.2.182283 with latest patch. I havent installed Clearpass 6.10.x Rollback RPM package, because that rolls it back to prev version, but I think this is not even necessery even though it is available?
AOS 2930F has been tested earlier versions and now running latest WC.16.11.0002
Tried to find missing attribute error fix with new version of clearpass and aos-switch.
I'm trying to setup MAC-auth with untauth vlan and then bounce port when profiled to auth vlan
> Device is profiled correctly to Printer, but the automatic bounce-port and manual change status>bounce port is failing
> second odd thing is that why type is "wireless" even though this is "wired" bounce that I need, is this just a terminology error inside CPPM?
Application Name |
Policy Manager |
RADIUS Dynamic Authorization Action Type |
Disconnect |
RADIUS Dynamic Authorization Action Name |
[ArubaOS Wireless - Bounce Switch Port] |
Status Code |
0 |
Status Message |
Radius [ArubaOS Wireless - Bounce Switch Port] failed for client f80.... Missing-Attribute. |
RADIUS Dynamic Authorization Attributes |
Aruba-Port-Bounce-Host = 12 Calling-Station-Id = f8-... |
In 2930F switch I have used time-windows 0, but it won't help either.
Both switch and cppm are using same windows dc ntp time and I have checked that there are no gaps.
Anything else I could try to get this working?
Thanks!
Olli Henttonen
