  • 1.  Clearpass CoA with ArubaOS switch
    Posted Jun 18, 2019 12:52 PM
    I want to change user role of a ArubaOS-Switch client with Clearpass CoA, however I can't get it work.
    using CP RADIUS Dyn Authorization Template: ArubaOs Switching-Change User Role, but
    manual trigger response via Monitoring-> Access Tracker-> Change Status -> RADIUS CoA is:
    "Radius CoA_user-role failed for client 001f29b6769c. Missing-Attribute."
    using RADIUS Dyn Authorization Template: ArubaOs Switching-Change VLAN doesn't work:
    "Insufficient parameters received"
    I am a bit confused here, are there necessary attributes that are not in clearpass template?
    MAC-Auth is working, User-Role profile "role-any" is configured locally on Aruba-2540 YC.16.06.0010 and ClearPass is on version 6.8.
    Any kind of help is appreciated.
  • 2.  RE: Clearpass CoA with ArubaOS switch
    Posted Jun 18, 2019 01:14 PM
    Did you add the device in ClearPass using hewlett packard enterprise as the vendor?
    Did you configure ClearPass to do dynamic authorization in the switch ?
    http://h22208.www2.hpe.com/eginfolib/networking/docs/switches/WB/15-18/5998-8152_wb_2920_asg/content/ch06s04.html#s_Configuring_the_switch_to_access_a_RADIUS_server
    Also make sure that the time on the switch and ClearPass is the same
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
