Clearpass - Connecting from VPN with RDP
This thread has been viewed 62 times
  • 1.  Clearpass - Connecting from VPN with RDP
    Posted Jan 01, 2023 06:13 AM
    I setup Clearpass cluster and assign VLANs to a workstation according to its Active directory user login.
    When the workstation is logged out there is no active VLAN on the port. Only dum VLAN (999) which is not configured on the network, only locally on the switches.
    As soon as login is processed, the interface got the correct VLAN for the user.
    My problem is when a client wants to connect to the workstation with RDP.
    When the workstation is not logged in, it has no IP address. So there isn't an option to connect to it.
    What is the best solution for that kind of problem?
    Generating a transition VLAN is the only possible way?
    And if it does, Do you have any suggestions what is the most secure way to configure this transition VLAN?
    Best regards,
    Alon Haber
  • 2.  RE: Clearpass - Connecting from VPN with RDP
    Posted Jan 01, 2023 09:33 PM
    You would have to configure machine authentication on the client machine for the device to  have an ip address when logged out.
  • 3.  RE: Clearpass - Connecting from VPN with RDP
    Posted Jan 02, 2023 10:11 AM
    If I put the interface on vlan access 999 and have connectivity in this VLAN (with access to DHCP server and to clearpass)
    Wouldn't it be enough for the machine to get IP address in vlan 999 ?
    Best regards,
    Alon Haber
  • 4.  RE: Clearpass - Connecting from VPN with RDP
    Posted Jan 02, 2023 10:27 AM
    If you are not doing any type of authentication on that port, yes.
  • 5.  RE: Clearpass - Connecting from VPN with RDP
    Posted Jan 04, 2023 04:39 AM
    I am doing authentication on that port.
    But I want to have some default VLAN that gives access to DHCP, DC, and Clearpass.
    Can't I put VLAN 999 in access, and only after authentication to replace the Vlan according to the User's AD credentials?
    Best regards,
    Alon Haber
  • 6.  RE: Clearpass - Connecting from VPN with RDP
    Posted Jan 04, 2023 05:53 AM
    That probably would work. Still, I would recommend configuring computer/machine authentication such that a logged-off computer can authenticate to the network rather than allowing even unauthenticated clients to connect to your AD services.
  • 7.  RE: Clearpass - Connecting from VPN with RDP
    Posted Jan 05, 2023 09:07 AM
    So if I am doing machine authentication.
    I can Gives it specific VLAN when it is loggod of, and another VLAN if it login (VLAN assigning according to the user AD credentials)?
    I am not sure what is the  flow when I am using both machine authentication and user authentication according to AD.
    Best regards,
    Alon Haber
  • 8.  RE: Clearpass - Connecting from VPN with RDP
    Posted Jan 05, 2023 11:20 AM
    That would be one option, but be aware that the client will need to do a DHCP renew when switching VLAN, which is why VLAN switching is not really recommended. It would be better to switch roles (to control traffic) and stick in the same VLAN; but if it works and is well tested, VLAN switching may work. For example roaming profiles may break/get corrupted if you switch VLAN in the middle of retrieving/saving. For that reason, just doing computer authentication and/or not switching VLANs may be the better option.
    In short, if you have machine+user, the computer will authenticate with the computer account when nobody is logged on, and reauthenticate as user when a user signs in.
  • 9.  RE: Clearpass - Connecting from VPN with RDP
    Posted Jan 08, 2023 04:01 AM
    Hi Herman,
    Thanks again.
    So among all your awesome videos. Do you have something that explains how to configure machine+user authentication?
    Best regards,
    Alon Haber
  • 10.  RE: Clearpass - Connecting from VPN with RDP
    Posted Jan 09, 2023 03:54 AM
    Did you see this video?
    And here is another video (from the older series) that shows where the client configuration is.
    Hope that helps?
  • 11.  RE: Clearpass - Connecting from VPN with RDP
    Posted Jan 09, 2023 05:09 AM
    Yes,
    I have just seen the first video you recommended.
    I will watch the older one as well, hoping to get it better.
    But I want to understand better the combination of a machine with user authentication.
    My plan was to switch VLANs according to the user credentials. So if it's an IT user he will get an IT VLAN. If it is a management user it will get mgmt VLAN. and so on.
    In the setup you suggested. I have to configure the VLAN on the port in advance, Don't I?
    So it makes the plan of VLAN switching problematic.
    Best regards,
    Alon Haber
  • 12.  RE: Clearpass - Connecting from VPN with RDP
    Posted Jan 09, 2023 03:37 PM
    any switching of VLANs breaks things like login scripts, etc and should be avoided at all costs.  It is even worse when you use RDP.
  • 13.  RE: Clearpass - Connecting from VPN with RDP
    Posted Jan 10, 2023 03:30 AM
    No, you don't need to configure a VLAN on the port in advance, you can assign a VLAN based on the Computer/Machine authentication.
    As Colin mentioned, you should avoid switching VLAN. If you want to change access, change User Roles instead and link the access to the User Roles.
    For new deployments, you may also have a look at TEAP which combines User+Computer authentication in a single (chained) authentication.
  • 14.  RE: Clearpass - Connecting from VPN with RDP
    Posted Jan 10, 2023 04:31 AM
    I understand what you are saying.
    But I have some gaps in the concept of machine authentication.
    My desire was to set a VLAN to a user according to its group on AD (IT, management, HR, etc...).
    But now, according to your solution, I need to bind a machine to the department. The only thing I can think of is to make this binding static, with some attribute for the endpoint.
    Did I get this right? Do you have any better idea for me on how to bind a machine to the correct VLAN? (Or better to say, the correct User role that has VLAN assignment)
    Best regards,
    Alon Haber
  • 15.  RE: Clearpass - Connecting from VPN with RDP
    Posted Feb 07, 2023 06:29 AM
    Hi Herman.
    I listen to your advice and configure machine authentication as well.
    It did solve my VPN connection problem to the station, But now I am having some case that I didn't manage to figure out.
    When a user is connecting to the network via VPN and then login in by RDP to its station. nothing is sent to the Clearpass.
    That means that it stays under machine authentication and doesn't do user authentication.
    Can you explain why? Or maybe I am missing some configuration?
    Best regards,
    Alon Haber
  • 16.  RE: Clearpass - Connecting from VPN with RDP
    Posted Feb 07, 2023 09:38 AM
    That seems to be as expected. If I read this correct, if a user logs in over RDP, Windows does not have access to the user credentials for 802.1X and falls back to computer authentication. You may ask this question through your Microsoft support channel.
  • 17.  RE: Clearpass - Connecting from VPN with RDP
    Posted May 17, 2023 05:02 AM
    Funny. But I am having now the same issue when I am using OnGuard.
    Without OnGuard I managed to get the authentication with "machine authentication".
    I configure the same for another network that uses OnGuard. The problem now is when I am trying to do RDP to end station, The Onguard posture is "Unkown" so the user-role sent to the switch is "Limited access" .
    How can I make sure that Onguard will send it's posture also when the user is logged out ?
    Best regards,
    Alon Haber
