Clearpass DHCP Relay for Profiling
  • 1.  Clearpass DHCP Relay for Profiling
    Posted Jan 24, 2019 02:14 PM
    Should the DHCP relays be sent to individual CLearpass IP, or can they be sent to the cluster VIP?
  • 2.  RE: Clearpass DHCP Relay for Profiling
    Posted Jan 25, 2019 07:57 AM
    I think either will work. There is some information on redundancy in the ClearPass Profiler Tech Note. Most examples point to the node address which in larger clusters allows the packet to be sent to the profiler nodes, but sending to a VIP makes sense as well in my opinion. In fact, the DHCP packet can arrive at any node in the cluster, so just make sure it gets there.
