You can do DUR without a public HTTPS certificate, but I'm quite sure that you need a PKI issued certificate. That can be from a private CA but self-signed is unlikely to work,
For the DUR, I would recommend that you configure the policy and role first in the switch manually, test/validate that it does what you want it to do, then you can take that configuration and add it as an advanced downloadable user role. You use the switch to do the syntax checking and know it works.
I would not deploy guest without a public HTTPS certificate. I have not tried myself it but have heard about people that got stuck at some point while attempting to configure it. With cert is best-practice and may save a lot of troubleshooting.
If you have urgent issues, always contact your HPE Aruba Networking partner, distributor, or Aruba TAC Support. Check
https://www.arubanetworks.com/support-services/contact-support/ for how to contact HPE Aruba Networking TAC. Any opinions expressed here are solely my own and not necessarily that of Hewlett Packard Enterprise or HPE Aruba Networking.
Original Message:
Sent: Apr 22, 2025 08:32 AM
Subject: Clearpass dynamic acl not working
Hi Herman,
I have a lab setup in my office using an Aruba IAP 505 & Aruba 2930f switch , but I currently don't have a public HTTPS certificate available. I'm working on a few test scenarios and would appreciate your input or guidance on the following:
Downloadable User Role (DUR) Testing with Aruba switch 2930f
Can DUR testing be performed in a lab environment without a public HTTPS certificate?
If yes, could you please share a detailed document or best practices for configuring and validating this?
want to achieve this using DUR.
I want to block access specifically from source IP 10.10.20.10 to destination 10.10.30.10.
I'd appreciate any configuration examples or tips on implementing this using user roles or access control lists on the IAP.
Guest Self-Registration (HTTP Only)
As part of testing, I'd like to configure guest self-registration using HTTP instead of HTTPS (since it's a closed lab setup).
Are there any recommendations or known limitations with using HTTP for captive portal testing in Aruba IAP 505?
Thanks in advance for your support. Let me know if you need any config files or further details from my end.
Best regards,
Rajat Sharma
Original Message:
Sent: Apr 16, 2025 10:41 AM
According to the rule syntax, source can only be any.
You may have a look at Downloadable User Roles as an alternative.
Original Message:
Sent: Apr 15, 2025 06:51 AM
this is working fine.... the requirement is block communication through the dynamic acl between subnet to subnet for example traffic from 10.10.20.0 to 10.10.30.0 must be block....
i tried multiple format but none of these are working....
this format shows the error on the switch
a request to all community member kindly give me solution for this.....
ClearPass Policy Manager 6.11.1.251304 on CLABV
Aruba 2930f switch
