  • 1.  Clearpass Endpoint Profiler
    Posted Jan 19, 2023 09:00 PM
    Hello, I have set up a policy to deny all laptops wireless access through the rule below.
    However, I found that a few laptops allowed wireless connection, and the devices were not getting information through Endpoint Profiler.
    When I looked at the endpoint profiler of devices that were connected wirelessly, I was unable to receive information.
    Is it a problem with the Clearpass setting that Clearpass cannot receive endpoint information?
    Or is it an endpoint configuration problem?
    If anyone knows, please leave a comment
  • 2.  RE: Clearpass Endpoint Profiler
    Posted Jan 20, 2023 01:21 AM
    at minimum, clearpass show see the DHCP request of devices and for that you can use ip-helper commands on the default gateway to also send the DHCP request to IP address of Clearpass. ClearPass will not respond to it but i needs t see the request.
    is that configured on the default gateway/switch for various VLANs?
  • 3.  RE: Clearpass Endpoint Profiler
    Posted Jan 20, 2023 10:42 AM
    What is your wireless NAD? Do you have RADIUS device profiling or IF-MAP enabled?
  • 4.  RE: Clearpass Endpoint Profiler
    Posted Jan 26, 2023 02:56 AM
    It is not possible to profile all endpoints.
    Most of the endpoint information is retrieved, but the information of a few specific devices cannot be retrieved.
    Looking at the Access Tracker, I found the following information:
    Failed to get value for attributes=[Category, Device Name, OS Family]
    Is the problem solvable with the solution you replied to?
    I'm new to the network and Aruba so I don't fully understand your replies. Sorry
  • 5.  RE: Clearpass Endpoint Profiler
    Posted Jan 26, 2023 07:45 AM
    Are these clients DHCP or static?  What method(s) are you using to get the profiling data into ClearPass?
  • 6.  RE: Clearpass Endpoint Profiler
    Posted Jan 26, 2023 12:06 PM
    The message:
    means that you authenticate a client which has not been profiled. This video may help you to setup the ip-helpers/DHCP relay for profiling.
    If you are new to Aruba, I would recommend to work with your Aruba partner. Setting up a good ClearPass deployment is not something that you can easily do without training and there are multiple 5 day trainings out there to get you up to speed.
  • 7.  RE: Clearpass Endpoint Profiler
    Posted Jan 29, 2023 07:44 PM
    I fixed the problem by sending DHCP to Clearpass through the Controller's IP-helper function.
    If so, how can we find out how the Endpoint Profiles collected before configuring the IP-helper were collected?
  • 8.  RE: Clearpass Endpoint Profiler
    Posted Jan 31, 2023 08:53 AM
    Not sure about your question.
    DHCP profiles are added to the endpoint, an may change the device category/name/type once they come in. There is no real 'before', except that at that point there probably was no profiling information.
