What the gateway of this vlan ? do you have look to use DHCP relay on this vlan ?
how to the device get the IP Address ?
ACEP / ACMX #107 / ACDX #1281
Original Message:
Sent: Mar 17, 2021 03:18 AM
Subject: ClearPass Endpoint Profiling not working
Yes, the switch can reach the CPPM.
In the access tracker I can see, that the right service is picked. The device is assigned into the right VLAN and gets an IP address assigned. This is working fine. But, the device is not profiled.
Matthias Pohl
Original Message:
Sent: Mar 16, 2021 03:59 PM
You need to found why...
the switch can reach the CPPM ?
Original Message:
Sent: Mar 16, 2021 11:19 AM
Hm, I´m not an expert, but to me it looks like, if CPPM doesn´t receive the DHCP packet
Matthias Pohl
Original Message:
Sent: Mar 16, 2021 10:14 AM
the 2530 have IP Address on each vlan ?
You can make a packet capture on CPPM
Original Message:
Sent: Mar 16, 2021 10:11 AM
How can I check if the CPPM receive the DHCP packet?
That was my understanding, to add the IP Helper on the 2530, so that the DHCP packet also get´s redirected to the CPPM, to be able to perform the profiling
Matthias Pohl
Original Message:
Sent: Mar 16, 2021 09:45 AM
Do you have look if the CPPM receive the DHCP packet ?
Why use IP Helper on the 2530 ? i think it is not the default gateway of the vlan ?
Original Message:
Sent: Mar 16, 2021 07:12 AM
Hi everybody,
i am not able to enable endpoint profiling in my CPPM. I have created a MAC-based authentication service with the following enforcement:
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/78c5620fe11e4252aececf4a5ebf68e7.png)
On my switch (HP 2530-8G-PoEP Switch (J9774A)) I´ve added the CPPM as IP helper on all VLANs. The device is redirected to VLAN401, but not profiled.
Any recommandations?
Kind regards,
Matthias
Matthias Pohl
