  • 1.  ClearPass enforcing role to Instant
    Posted Mar 12, 2014 03:17 PM
    I'm having trouble passing a Role to an Instant using ClearPass.
    It's not clear if I'm going about this the right way. This is my first attempt at doing this.
    I have a Employee SSID setup on Instant to use ClearPass Onboard to provision and authenticate users.
    The default role on the Employee SSID has a external captive portal, which points to the Onboard QuickConnect app.
    That part works great.  I can log-in, go to the portal, download quickconnect, and install certificates. Works just like the normal controller based routine.
    The problem I'm having is getting the ClearPass to change the default role of the Employee SSID to something else (allow all).
    Without changing the default role, my client con only get to the captive portal.
    I've got user roles setup in both ClearPass and Instant with the same name.
    My ClearPass service for Onboard Provisioning is applying the right role. Looking at the Access Tracker, roles and enforcement prfiles are being correctly assigned.  I'm not sure if they are being accepted by the Instant AP.
    I basically have two settings on my Onboard Provisioning.
    First is the Role tab.  I setup a role in ClearPass and it gets assigned.
    Second is the Enforcement tab.  I have an enforcement profile set to the following:
    Radius:Aruba    Aruba-User-Role  CRA_Instant          ( type,name,value) ("CRA_Instant" is the name of my Role I'm trying to apply)
    Now the canned choices from the drop-down menu are nothing like the value I have above.  Most look like %{Authorization:Active Directory:Name}  or something similar.  I'm not sure if I can just type in the name of a role I configured or if I have to use the language that is part of the drop down.
    Nothing in the drop-down list by default looks to be anything I could use in terms of Roles.
    Maybe using enforcement as described above is not the way to go about this?
    Any help, especially if I'm going off on a tagent is appreciated.
    Colin
  • 2.  RE: ClearPass enforcing role to Instant
    Posted Mar 12, 2014 05:31 PM
    You can simply type the name (case-sensitive) of the Aruba user role there.  You don't need to worry about the drop down list.
    Can you cut and paste the IAP config?
  • 3.  RE: ClearPass enforcing role to Instant
    Posted Mar 12, 2014 06:31 PM
    Full config file attached.
    CRA_IAP_Employee  is the SSID I'm having issues with.
    Default access role woudl be "CRA_IAP_Employee"
    Access role I'm trying to apply is "CRA_Instant"
    The SSID config tab for Access Rules , as viewed in the GUI,  defaults to Network-based.  Reading from prior posts this is expected and as-designed.
    What I'm not sure of, is if I send a RADIUS request to change the role from default, will the config change to role based?
    Here are the config portions that may be of interest (not in order shown in config file):
    wlan ssid-profile CRA_IAP_Employee
    enable
    index 1
    type employee
    essid CRA_IAP_Employee
    opmode wpa2-aes
    max-authentication-failures 0
    vlan 15
    auth-server clearpasscra
    rf-band all
    captive-portal disable
    dtim-period 1
    inactivity-timeout 1000
    broadcast-filter none
    dmo-channel-utilization-threshold 90
    local-probe-req-thresh 0
    max-clients-threshold 64
    wlan access-rule CRA_Instant
    index 2
    rule any any match any any any permit
    wlan access-rule CRA_IAP_Employee
    index 3
    captive-portal external profile Employee
    rule 10.1.100.128 255.255.255.255 match tcp 443 443 permit
    rule 10.1.100.128 255.255.255.255 match tcp 80 80 permit
    rule 173.194.0.0 255.255.0.0 match tcp 443 443 permit
    rule 74.125.0.0 255.255.0.0 match tcp 443 443 permit
    rule 209.85.0.0 255.255.0.0 match tcp 443 443 permit
    rule any any match any any any deny
    wlan auth-server clearpasscra
    ip 10.1.100.128
    port 1812
    acctport 1813
    key 3ab42c4060d6db48e5882ecb4b2a0e696756c5120a1185ff
    rfc3576
    cppm-rfc3576-port 5999
    wlan external-captive-portal Employee
    server 10.1.100.128
    port 443
    url "/guest/landing.php/device_provisioning2.php"
    auth-text ""
    auto-whitelist-disable
    https
    Attachment(s)
    txt
    instant.txt   5 KB 1 version
