ClearPass - Error 404 with EAP TLS with SAN intunedeviceid://
This thread has been viewed 55 times
  • 1.  ClearPass - Error 404 with EAP TLS with SAN intunedeviceid://
    Posted Apr 15, 2024 05:03 AM
    ClearPass version : 6.11.7.257550
    Extension Microsoft Intune : 6.1.7
    We can use the extension with the deviceid in the common name. But when we try to use in the SAN only, we got an error 404 ::
    We use Microsoft PKI Cloud to deploy the certificate and we must specify intunedeviceid:// in the SAN field in intune configuration (without, the certificate won't be deploy) :
    The certificate look likes :
    Someone can confirm that the extension works only with URL={{deviceid}} and doesn't support intunedeviceid:// please ?
    I found in an other discussion the same information (problem with intunedeviceid://) but I need to confirm that we don't have a workaround.
    Thanks.
  • 2.  RE: ClearPass - Error 404 with EAP TLS with SAN intunedeviceid://
    Posted Apr 15, 2024 07:30 AM
    ClearPass does not recognize the URL-form, intunedeviceid:// and will send the full attribute to Intune, which fails.
    Make sure that you have just the DeviceID somewhere in a certificate field as an isolated attribute. Here is an example where I put the DeviceID in many different certificate fields:
    So you can even put it in the Location, OU, Country or whatever other attribute in the DN; or in an unused SAN (just make sure there are not multiple attributes of the same time, like in my example (and your case) with the URI SAN. It would be nice if ClearPass could be configured to extract it from a field, like the IntuneDeviceId: URL SAN, but that's not possible as far as I know.
  • 3.  RE: ClearPass - Error 404 with EAP TLS with SAN intunedeviceid://
    Posted Apr 15, 2024 11:40 AM
    Hi Herman,
    Thanks for this detailed response. We will try several things with this new pki cloud ...
  • 4.  RE: ClearPass - Error 404 with EAP TLS with SAN intunedeviceid://
    Posted Feb 19, 2025 02:12 AM
    @Herman Robers - has there been any updates on this?
    It would be cleaner from a certificate deployment if ClearPass could be configured to extract it from a field, like the IntuneDeviceId: URL SAN rather than use another field.
  • 5.  RE: ClearPass - Error 404 with EAP TLS with SAN intunedeviceid://
    Posted Feb 19, 2025 02:54 AM
    Yes, since extension version 6.3 there is support for parsing the SAN-URI fields. The attribute name for the Intune Device ID would be DeviceId, but the idea is similar (screenshots and more info in the documentation):
    Supported KEY:VALUE pairs are as follows. The KEY names used are same as the variable names that Intune supports in the SCEP profile. Please refer the below link from Micrsoft for details.
    https://learn.microsoft.com/en-us/mem/intune/protect/certificates-profile-scep
    1. DeviceId:{{DeviceId}} - Used for Intune attributes lookup.
    2. AAD_Device_ID:{{AAD_Device_ID}} - Used for both Intune attributes and Device group membership lookup.
    3. UserPrincipalName:{{UserPrincipalName}} - Used for User group lookup only when user group lookup using extension is enabled.
  • 6.  RE: ClearPass - Error 404 with EAP TLS with SAN intunedeviceid://
    Posted Feb 19, 2025 05:24 PM
    @Herman Robers - doesn't seem to like EAP-TEAP as machine auth only (method-1), still getting the 404 error with no authorisation attributes even though the DeviceId is listed in the access tracker information.
    EAP-TEAP access tracker information:
    Works fine if connection is EAP-TLS only with the same authorisation source.
    Is this expected?
  • 7.  RE: ClearPass - Error 404 with EAP TLS with SAN intunedeviceid://
    Posted Feb 24, 2025 04:57 AM
    I would have a look at the extension logs, and verify there what is seen and if the Intune Device ID matches what you have in Intune.
    It may be easier to work with your partner or TAC and step-by-step check what identifiers are being used/sent and why you see a 404 which means that the device is not found, in most cases it points to a wrong DeviceId being sent.
  • 8.  RE: ClearPass - Error 404 with EAP TLS with SAN intunedeviceid://
    Posted Mar 05, 2025 02:20 AM
    Tobi are you able to share a screenshot of the SCEP device certificate profile in Intune? I am also having trouble getting this this up and running.
    I am using Intune Cloud PKI and when i add URI attributes the certificate gets removed from the device.
    Cloud PKI
  • 9.  RE: ClearPass - Error 404 with EAP TLS with SAN intunedeviceid://
    Posted Mar 05, 2025 02:44 AM
    @Herman Robers,
    All seems to be ok after redoing the SCEP certificates and restarting the ClearPass appliance. Will continue to monitor before considering rolling out to our production instance.
    @SimondsCC - we are not using the Intune Cloud PKI but details and screenshots below.
    You will need the Intune details in the USER SCEP certificate as well if you are doing user-based authentication with EAP-TLS or EAP-TEAP.
    As Herman mentioned they need to be in a specific format for ClearPass to use them:
    DeviceId:{{DeviceID}}
    SCEP Device:
    SCEP User:
    We've also got a couple of other SAN attributes in the certs not required for ClearPass and all seems ok.
    Hope this helps.
  • 10.  RE: ClearPass - Error 404 with EAP TLS with SAN intunedeviceid://
    Posted Mar 10, 2025 11:16 PM
    Tobi don't forget the new strong-mapping requirement for hybrid machines, adding another SAN URI of {{OnPremisesSecurityIdentifier}}
    https://arubanetworking.hpe.com/techdocs/NAC/clearpass/integrations/unified-endpoint-management/intune/#whats-new-in-clearpass-intune-extension-v63
    What SCEP server are you using? I am just wondering why everyone doesn't just use the Clearpass native SCEP?? I am thinking I will use this after our MS Cloud PKI issue with SAN values being changed to lowercase, yet Clearpass Intune extension mandates case sensitivity, hence our HTTP lookup is not working.
  • 11.  RE: ClearPass - Error 404 with EAP TLS with SAN intunedeviceid://
    Posted Mar 10, 2025 11:42 PM
    Hi Brendan,
    As we don't have hybrid machines, I haven't configured that but will in the future if required.
    Here's a Microsoft article on Configure infrastructure to support SCEP certificate profiles with Microsoft Intune | Microsoft Learn.
    I could be wrong, but I believe ClearPass native SCEP will consume an Onboard licence.
  • 12.  RE: ClearPass - Error 404 with EAP TLS with SAN intunedeviceid://
    Posted Mar 11, 2025 01:05 AM
    Edited by BrendanMYS Mar 11, 2025 01:06 AM
    Thanks Tobi and good catch. From my quick research the Onboard licenses work out slightly cheaper than the MS Cloud PKI licenses but only just!
    Crazy idea maybe - is there any reason we couldn't use the Intune MDM certificate to authenticate with? I realize it doesn't have the right SAN values to use HTTP method but it would work fine with Endpoint DB lookup as long as you imported the CA certs it was signed with.
  • 13.  RE: ClearPass - Error 404 with EAP TLS with SAN intunedeviceid://
    Posted Mar 11, 2025 02:07 AM
    Key consideration is security - you would be trusting any certificate from that certificate chain as your first 'gate'.
    Can you do things like revoke the certificate, etc if compromised?
    What other controls would you implement to restrict access?
    Main reason we've been looking into the HTTP method is because the Endpoint DB will only be populated by the Intune extension once a MAC is recorded in Intune, and have found significant delays in that process (Intune not ClearPass).
