Clearpass guest access portal - MAB - web authentication
This thread has been viewed 30 times
Alex_Bondar
Alex_BondarJan 15, 2014 04:13 AM
  • 1.  Clearpass guest access portal - MAB - web authentication
    Posted Sep 20, 2013 01:21 AM
    Hi Guys,
    We are implementing guest access to our wired network. So, we have configured 802.1x, MAB (Mac address bypass authentication) in switch ports to authenticate the users connecting to it.
    So, if a user connects to a switchport and if he fails in both 802.1x and MAB, he is treated as guest user and should be given clearpass guest portal web login page (to create his own account to login).
    Normally in CISCO ISE, we have an option to use 'If user_not_found in MAB, ISE will not fail MAB, rather it will send redirect url (of ISE guest portal) to switch to ask the user to login to the guest portal page'. [You could refer to page 4 of the attached document)
    So, in clearpass, do we have an option like 'If the user is failing MAB, the clearpass sends the re-direct url to the switch to make the user login to clearpasss guest portal'? I don't find one because if he is failing MAB, the only option we're left is to use switch's internal web page (web-auth - fallback method for MAB).
    Any service/enforcement policy needs to be created for this to accomplish? Please help.
    Bharani.....
    Attachment(s)
  • 2.  RE: Clearpass guest access portal - MAB - web authentication
    Posted Sep 20, 2013 01:46 AM
    Yes you can send back a ACL with a url redirect, along with a vlan in your mac auth service for unknown devices
    Sample ACL
    Sample enforcement
  • 3.  RE: Clearpass guest access portal - MAB - web authentication
    Posted Sep 20, 2013 02:00 AM
    Hi Troy,
    Thank you for quick answer. But this enforcement policy and profiles will be applied only when the client is being authenticated by anyone of the authentication sources right?
    Because in our case, the new user will not be getting authenticated by either guest_user_repository or any sources. So, eventually we're getting MAC AUTH TEST failure (user not found) and policies are not enforced.
    But the requirement is even though the user's MAC address is not known by clearpass, it should be sending ACL abd redirect to switch which is not happening in our case :(
    What authentication source should I use in this case? How to proceed this?
    Bharani.....
  • 4.  RE: Clearpass guest access portal - MAB - web authentication
    Posted Sep 20, 2013 02:18 AM
    When the user fails .1x the device will be authenticated with MAB and instead of sending a reject you can catch all unknown devices and put them to the captive portal.
    You can use the endpoints database as an auth source and use the guest user/device repositories as a Authorization for the role mapping.
    Here are a few screen shots. You can work with your local SE and he can show you an example in our lab.
  • 5.  RE: Clearpass guest access portal - MAB - web authentication
    Posted Sep 20, 2013 06:37 AM
    Hi Troy,
    I think this is exactly what I'm looking for! I'll give a try on this on Monday and let you know the result.
    Bharani...
  • 6.  RE: Clearpass guest access portal - MAB - web authentication
    Posted Jun 18, 2019 06:40 AM
    hi bharani
    i have the same issue as your mentioned. i just build the environment with cisco swicth and clearpass for web authentication. follow the adive, i set the authentication methods  "allow all mac auth" for the unknown mac continueing to go to web-auth. but the switch does not receive the redirect url. it seems just like the mab authentication is pass.
    Do i miss some configuration on clearpass? thanks
    switch result:
    bogon#show authentication sessions interface GigabitEthernet0/20
    Interface: GigabitEthernet0/20
    MAC Address: 089e.019e.ccfe
    IP Address: 10.10.51.129
    User-Name: 089e019eccfe
    Status: Authz Success
    Domain: DATA
    Security Policy: Should Secure
    Security Status: Unsecure
    Oper host mode: multi-auth
    Oper control dir: both
    Authorized By: Authentication Server
    Vlan Policy: N/A
    Session timeout: N/A
    Idle timeout: N/A
    Common Session ID: 0A0A33CD000000AD01EB0EE4
    Acct Session ID: 0x00000094
    Handle: 0x030000AE
    Runnable methods list:
    Method State
    mab Authc Success
  • 7.  RE: Clearpass guest access portal - MAB - web authentication
    Posted Dec 25, 2019 02:10 AM
    @mikek wrote:
    hi bharani
    switch result:
    Domain: DATA
    Vlan Policy: N/A
    Idle timeout: N/A
    Handle: 0x030000AE
    Method State
    mab Authc Success
    Hi Mikek,
    Did you get to make this work? Running into a similar issue here.
  • 8.  RE: Clearpass guest access portal - MAB - web authentication
    Posted Sep 22, 2013 05:03 AM
    Hi Troy,
    Yes, I've test your settings, I can authenticate myself successfully even the authentication source is none. Just a small question. When we add in the authorization source, do we need to add in all these 4 provided by you? Or you we just need to add in endpoint plus guest device repo?
    *Mar 5 04:32:44.985: %AUTHMGR-7-FAILOVER: Failing over from 'dot1x' for client (0015.5882.8823) on Interface Fa0/2 AuditSessionID 0AA7DC2F000000381592C511
    *Mar 5 04:32:44.985: %AUTHMGR-5-START: Starting 'mab' for client (0015.5882.8823) on Interface Fa0/2 AuditSessionID 0AA7DC2F000000381592C511
    *Mar 5 04:32:45.027: %MAB-5-SUCCESS: Authentication successful for client (0015.5882.8823) on Interface Fa0/2 AuditSessionID 0AA7DC2F000000381592C511
    *Mar 5 04:32:45.027: %AUTHMGR-7-RESULT: Authentication result 'success' from 'mab' for client (0015.5882.8823) on Interface Fa0/2 AuditSessionID 0AA7DC2F000000381592C511
    *Mar 5 04:32:46.067: %AUTHMGR-5-SUCCESS: Authorization succeeded for client (0015.5882.8823) on Interface Fa0/2 AuditSessionID 0AA7DC2F000000381592C511
    Shawn
  • 9.  RE: Clearpass guest access portal - MAB - web authentication
    Posted Sep 22, 2013 05:20 AM
    It all depends on if you are doing time or bandwidth restrictions.
    Its not required but I'm using the insight and endpoints database for post auth checks.
  • 10.  RE: Clearpass guest access portal - MAB - web authentication
    Posted Sep 20, 2013 02:41 AM
    Bharani,
    You can clone the MAC auth authentication method and in your copy you can enable "Allow Unknown End-Hosts".
  • 11.  RE: Clearpass guest access portal - MAB - web authentication
    Posted Sep 20, 2013 06:38 AM
    HI Joseph,
    Thanks for your reply. I'll get back to you on monday..
  • 12.  RE: Clearpass guest access portal - MAB - web authentication
    Posted Sep 22, 2013 02:17 AM
    Hi Troy,
    Could you share the Cisco config that you used to get this working? Also, is this functionality supported in IOS 12.2+, or do you need version 15+?
    Thanks!
    -Mike
  • 13.  RE: Clearpass guest access portal - MAB - web authentication
    Posted Sep 22, 2013 03:35 AM
    Min version is 12.2
    ########Apply this to your switch###########
    aaa new model
    aaa authentication dot1x default group radius local
    aaa authorization network default local group radius
    aaa authorization auth-proxy default group radius
    aaa accounting dot1x default start-stop group radius
    aaa server radius dynamic-author
     client 10.xx.xx.xxx server-key 0 test123
     port 3799
     auth-type all
    aaa session-id common
    vtp mode transparent
    ip routing
    ip domain-name arubademo.net
    ip name-server 10.xx.xx.xxx
    ip device tracking
    dot1x system-auth-control
    vlan 201
    interface Vlan1
     ip address <vlan1_provided_ipaddr> 255.255.248.0
    interface Vlan200
     description "user_vlan"
     ip address <vlan200_provided_ipaddr> 255.255.254.0
    interface Vlan201
     description "quarantine_vlan"
     ip address <vlan201_provided_ipaddr> 255.255.254.0
    ip route 0.0.0.0 0.0.0.0 10.xx.xx.1
    ip classless
    ip http server
    ip http secure-sever
    ip access-list extended Onboard-ACL
     deny   tcp any 216.115.208.0 0.0.15.255
     deny   tcp any 216.219.112.0 0.0.15.255
     deny   tcp any 66.151.158.0 0.0.0.255
     deny   tcp any 66.151.150.160 0.0.0.31
     deny   tcp any 66.151.115.128 0.0.0.63
     deny   tcp any 64.74.80.0 0.0.0.255
     deny   tcp any 202.173.24.0 0.0.7.255
     deny   tcp any 67.217.64.0 0.0.31.255
     deny   tcp any 78.108.112.0 0.0.15.255
     deny   tcp any 206.183.100.0 0.0.7.255
     deny   tcp any 68.64.0.0 0.0.31.255
     deny   tcp any 173.199.0.0 0.0.63.255
     deny   tcp any 103.15.16.0 0.0.3.255
     deny   tcp any 180.153.30.0 0.0.1.255
     permit tcp any any
    radius-server host 10.xxx.xxx.xxx auth-port 1812 acct-port 1813 key 0 test123
    radius-server vsa send authentication
    ntp clock-period 36029439
    ntp server 10.xx.xxx.101
    ##############Apply this to your uplink interface (replace X/X/X below)#################
    interface FastEthernetX/X/X
     description "Uplink to test Lab"
     switchport trunk encapsulation dot1q
     switchport trunk allowed vlan 1,200,201
     switchport mode trunk
     spanning-tree portfast trunk
    ##############Apply this to your user interfaces (replace X/X/X below)#################
     switchport access vlan 200
     switchport mode access
     authentication event no-response action authorize vlan 201
     authentication host-mode multi-auth
     authentication order dot1x mab
     authentication priority dot1x mab
     authentication port-control auto
     authentication periodic
     authentication timer reauthenticate server
     mab
     dot1x pae authenticator
     dot1x timeout tx-period 20
     dot1x timeout supp-timeout 20
     dot1x max-reauth-req 1
  • 14.  RE: Clearpass guest access portal - MAB - web authentication
    Posted Sep 25, 2013 02:15 PM
    Troy,
    One more question about your configuration. You have the following line set on the interface:
    How are you sending back the reauthentication timer from Clearpass to the server? I'm doing something similar right now, so just curious.
    Thanks!
    -Mike
  • 15.  RE: Clearpass guest access portal - MAB - web authentication
    Posted Sep 25, 2013 05:15 PM
    In the enforcement you change the session-timeout. For example in this one I changed it to 3600 sec which is every hour.
  • 16.  RE: Clearpass guest access portal - MAB - web authentication
    Posted Sep 25, 2013 06:40 PM
    Troy,
    You know it's funny, I've only changed the VLAN number in the default VLAN policy - I've never actually read the other fields.
    Thanks for that pointing that out!
    -Mike
  • 17.  RE: Clearpass guest access portal - MAB - web authentication
    Posted Jan 13, 2014 09:58 AM
    Hi everyone,
    I'm working on the same task as you do (wired centralized web-auth like Cisco ISE)
    My service setup is like your (allow all mac-auth, url redirect returned, user's http traffic redirected, credentials are posted, etc. - it's OK), but I have next trouble:
    When guest account expires, exsisting session are not disconnected automatically :( ,while If I do this manually (from Guest app ->actice sessions -> disconnect) - it works
    CPPM version - 6.2.4
    Cisco catalyst 3750-x IOS 12.2(55)SE3
    I also attached services, which I use (.xml)
    Can you advice anything?
    thanks )
  • 18.  RE: Clearpass guest access portal - MAB - web authentication
    Posted Jan 15, 2014 04:03 AM
    Would be awsome if the OP could post screens for the service and all related components for the end-result that seems to be working. Any chance that happening? :)
  • 19.  RE: Clearpass guest access portal - MAB - web authentication
    Posted Jan 15, 2014 04:13 AM
    Agree :)
    This would be great !
  • 20.  RE: Clearpass guest access portal - MAB - web authentication
    Posted Apr 12, 2019 12:58 AM
    Hi ,
    While doing the wired guest self registration with Aruba switch , User connect and re-direct to the capitive portal, User register the required field and submitting the credential to validate the clearpass server .
    How the user request is catergorized into clearpass service web authentication and hit the service and authenticate .
    Can anyone please help me on this
    @Bharani wrote:
    Hi Guys,
    Bharani.....
  • 21.  RE: Clearpass guest access portal - MAB - web authentication
    Posted Apr 12, 2019 01:39 AM
    The wired captive portal authentication is different from the wireless one. In the guest page use the vendor "Hewlett Packard Enterprise" and set the Pre-Auth check to none
    There should be a request in the access tracker.
    The service within policy manager should be set to Web based authentication type.
    In the service rules you can use the following
  • 22.  RE: Clearpass guest access portal - MAB - web authentication
    Posted Apr 12, 2019 02:56 AM
    Hi ,
    Yes i selected NAS setting as HP Enterprise and pre-auth check is unchecked .
    And service side -- > Web auth
    HoST - - > CHEK TYPE --- > EQUALS --- > Authentication ..
    And not included the guest page in service , only one rule in service
    Can please explain the workflow , user submitting the credntial with capitive portal the request is classified as web auth service and hitting the CPPM server .
    Ans i see this in access tracker ..
