Network Management
  • 1.  Clearpass Guest Device Question
    Posted Mar 05, 2025 09:14 AM
    Edited by JM11 Mar 05, 2025 09:25 AM
    Hello all,
    I'm creating a new device on the Guest side and I want to be able to assign it a custom Account Role.
    Does anyone know exactly where the Account Role field pulls it's values from so I can edit the list and add options?
    I thought it came from my MPSK role mapping since most of these appear in the list.  But I can't get the last two I added to show up in the drop down list of the Account Role field.
    Thanks!
  • 2.  RE: Clearpass Guest Device Question
    Posted Mar 05, 2025 09:28 AM
    You need to update the Role Mapping "[Guest Roles]". After you've update this role mapping the new roles will appear in Guest.
    Willem Bargeman
    Systems Engineer Aruba
    ACEX #125
  • 3.  RE: Clearpass Guest Device Question
    Posted Mar 05, 2025 10:06 AM
    Thanks for the reply.  Not sure if you saw my post before I edited it and added the role mapping picture.  I've added the last two, and yet they don't show up in the drop down list:
    It's not showing Precision Laptop or MTB Laptop in the drop down even though I have it in my role mapping.
  • 4.  RE: Clearpass Guest Device Question
    Posted Mar 05, 2025 10:18 AM
    Yes I saw that one. But you need to update another Role Mapping.
    The dropdown box in Guest is only checking the role mapping "[Guest Roles]".
    Willem Bargeman
    ACEX #125
  • 5.  RE: Clearpass Guest Device Question
    Posted Mar 05, 2025 10:53 AM
    Yup, that was it!
    Thank you sir!
