In the Create Device and Create Account forms you can specify the expiration for each device and guest account.
This is the form for the Create Device:
Default values are set in each form, but can be changed by the person who adds the device, if the field is enabled in the operator profile assigned to the user.
Best Regards
Jonas Hammarbäck
MVP Guru, ACEX, ACDX #1600, ACCX #1335, ACX-Network Security, Aruba SME, ACMP, ACSA
Aranya AB
Original Message:
Sent: Mar 04, 2025 09:49 AM
Subject: ClearPass Guest / IOT MPSK expiry
Hi Willem,
I was told it was a global setting in ClearPass guest that only one expiration time could be used. I will go back to the engineer to find out what the problem is.
Jason
Original Message:
Sent: Mar 04, 2025 09:16 AM
You mean different expiration times for IoT devices and guest devices? Yes that is possible. While creating a guest or device account the account expiration time can be selected.
Willem Bargeman
Systems Engineer Aruba
ACEX #125
Original Message:
Sent: Mar 04, 2025 07:46 AM
We have a customer with ClearPass. They are guest the guest portal for standard guest registration and also for IoT / MPSK registration.
It is possible to have different timeouts per profile such as guest 5 days, IoT 1 year?
The guest and IoT SSID are different.
Jason
