Hi
I have setup Guest portal with self-registration and sponsor and use different roles (also two custom ones).
Mac-caching works fine and new roles are send to controller correctly via Radius CoA.
In my setup, guest obtain default guest role after registration and changing of role is done from ClearPass-Guest->Manage Accounts.
(Changing of role isn't done from sponsor form)
One problem which I have encounter is that I don't know how to send new role of guest to the Endpoint Repository after modyfing it in the guest account (from ClearPass-Guest->Manage Accounts).
If I change it manually in this endpoint repository, it is ok, but it is not comfortable for my client.
Is it any way to change the role in Endpoint Repositury automatically after account modification ?
I would be very glad for any help and advices
Karol
