  • 1.  Clearpass Guest send credentials to email
    Posted Nov 28, 2024 11:42 AM
    Hi all
    We have a running config on Clearpass and guest using sponsor email.
    Now we need to create a new Guest network, but we need to have sure that user email is valid and user receive a email with credentials .
    What needs to be changed on the self registration '?
    Hope you can help
    Regards
  • 2.  RE: Clearpass Guest send credentials to email
    Posted Nov 29, 2024 03:06 AM
    Remove or disable the password field from the receipt form:
    The password won't be displayed, so has to be retrieved from the mail or SMS/Text, which validates reception and valid mail or phone number.
  • 3.  RE: Clearpass Guest send credentials to email
    Posted Nov 29, 2024 10:57 AM
    Hi Herman
    So we only need to remove the password field?
    Also How can we force that users are forced to go to email, without sponsor
    We need that,  in the registration, user puts a valid email and then he receives a mail with password to login.
    If the mail is fake or does not exists , user is not able to login, since he did not received password ��
    Regards
    Bruno Costa
    IT Support Specialist
    CONNECTing Projectos e Consultoria Lda.
    Rua Diogo de Silves, 33C
    1400-107 Lisboa
    Tlm: +351 916 158 228
    Email: baraujo@connecting.pt
    internet: www.connecting.pt
    _____________________________________________________________________________________________________________________________
    THIS MESSAGE MAY CONTAIN INFORMATION THAT IS PRIVILEGED AND CONFIDENTIAL.
    The information contained in, or attached to, this message is intended solely for the use of the specific person(s) named above.
    If you are not the intended recipient then you have received this communication in error and are prohibited from review, retransmission, taking any action in reliance upon, sharing the content of, disseminating or copying this message and any of the attachments in any way.
    If you have received this communication in error, please contact the sender immediately and promptly delete this message from all types of media and devices. Thank you
