ClearPass Guest system deployment
  • 1.  ClearPass Guest system deployment
    Posted Dec 11, 2013 08:32 AM
    I have already deployed over 802.1 x , I now to deploy the guest system,But I have what time it is not clear;
    1.Controller configure authentication type is L3 authentication,
    2.I  want to Guest SSID to connect visitors will redirect to a page,What kind of authentication type CCPM need to use?
    How to configure authorization page?
    Thanks!
    [Mod note: adjusted subject text]
  • 2.  RE: ClearPass Guest system deployment
    Posted Dec 11, 2013 08:35 AM
    You should use a "service template" to configure the guest network on CPPM.  That will simplify creating the services.
  • 3.  RE: ClearPass Guest system deployment
    Posted Dec 11, 2013 08:42 AM
    Please read the attached doc, it will guide through the setup.
  • 4.  RE: ClearPass Guest system deployment
    Posted Dec 11, 2013 08:43 AM
    I should use a "service template-----Guest Access" ?
    2.But I will lead to the page before configuration is redirected to the following page;How to deal with it, or how to temporarily turn off this feature?
  • 5.  RE: ClearPass Guest system deployment
    Posted Dec 11, 2013 08:51 AM
    1.  Yes
    2.  The page should be:  https://<ip address of cppm>/guest/guest.php
  • 6.  RE: ClearPass Guest system deployment
    Posted Dec 11, 2013 09:19 AM
    Thank you very much;
    But I see the document set the redirect url inside there is no https:// (CCPM - IP)/guest
    The configure of the guide is like this: For example,https://x.x.x.x/web_auth.php
    At the bottom of the screenshots;
  • 7.  RE: ClearPass Guest system deployment
    Posted Dec 11, 2013 09:21 AM
    Yes, if you change the default, that is what it should be, what is in the screenshot.  You should be able to click on Test on the Weblogin, to see what URL it should be.
  • 8.  RE: ClearPass Guest system deployment
    Posted Dec 11, 2013 09:39 AM
    The picture as you say,But after the last connection Guest SSID, will be redirected to the OnGuard Portal, as shown in figure;
    I'll be greatly appreciatived for your answer;
  • 9.  RE: ClearPass Guest system deployment
    Posted Dec 11, 2013 09:43 AM
    Is that what happens when you go to https://<ip address>/guest/cisco_web_auth.php?
  • 10.  RE: ClearPass Guest system deployment
    Posted Dec 11, 2013 09:47 AM
    After I connect Guest SSID,Expectations are redirected to a page (https://x.x.x.x/guest/cisco_web_auth.php)
    But,But it is redirected to another page(https://x.x.x.x/guest/cisco_web_auth/........php),Has increased a lot uri ;
  • 11.  RE: ClearPass Guest system deployment
    Posted Dec 11, 2013 09:54 AM
    Do you have the proper URL in the WEB Auth portion of the Cisco controller?  If you do, you should open a TAC case to determine what is creating the extra characters..
  • 12.  RE: ClearPass Guest system deployment
    Posted Dec 11, 2013 09:57 AM
    Ok, I again under test,Thanks!
  • 13.  RE: ClearPass Guest system deployment
    Posted Dec 12, 2013 05:47 AM
    Hi,You also need to please teach you;
    Today I tested the Guest system,Visitors since the registration is successful, and can make a successful authentication;
    I used a “service-template(Guest Access)”,but Visitors can't get authorization;Although showing authorization, but the result of the test is not;
    How do I go about configuration, to be able to get the corresponding authorization?
  • 14.  RE: ClearPass Guest system deployment
    Posted Dec 12, 2013 07:11 AM
    I am unsure of your question.  What are you asking help for and what is the issue?
  • 15.  RE: ClearPass Guest system deployment
    Posted Dec 12, 2013 08:01 AM
    I do visitors according to service template system;
    According to the wizard done, I use the wireless Guest SSID test;
    The test can be from the date of successful registration and certification;
    But I need to do an authorization to make the number of registered users cannot access the internal network, So I made an Enforcement polices,When I reconnect the SSID, authentication passed, but didn't get the expected authorization (VLAN20 authorization);
    Note: The Wireless controller did not show the authorization,But show on CPPM vlan20 authorization;
    What should I do??
  • 16.  RE: ClearPass Guest system deployment
    Posted Dec 14, 2013 12:33 AM
    You need to post a screen shot of your enforcement Profile.
    If this is a cisco WLC you need to make sure you have airspace dictionary enabled and you have the proper enforcement profile.
    for example this is a cisco airspace named acl.....
