ClearPass hostname VS. FQDN
  • 1.  ClearPass hostname VS. FQDN
    Posted Feb 10, 2017 01:20 AM
    Hi Forum,
    Can a ClearPass have a hostname that is different from the FQDN of that box?
    I want to have my RADIUS cert with the hostname (that is an internal name) in the CN and to have the FQDN (resolvable by guests)as the CN for the HTTPS cert.
    thanks,
  • 2.  RE: ClearPass hostname VS. FQDN
    Posted Feb 10, 2017 04:43 AM
    You don't need the actual hostname/FQDN on CPPM to equal the CN on a cert. Just create the DNS entry and make it resolvable to whichever IP address on CPPM, create the cert for that DNS name and assign it as the RADIUS or HTTPS certificate.
  • 3.  RE: ClearPass hostname VS. FQDN
    Posted Feb 10, 2017 07:36 AM
    The RADIUS CN does not need to be resolvable.
