  • 1.  Clearpass http Auth Intune attributes
    Posted Feb 13, 2025 04:23 AM
    I am trying to pull in attributes when a wired connection is made.
    I have setup the http request with the following information.
    i am using the attributes below
    when the client connects i am getting the following alert
    I have the Intune extension working and pulling endpoints into the local endpoint database so i know the extension is working.
    I have tried changing the base URL to http://172.17.0.2 but still get the same error.
    any assistance would be greatly appreciated
  • 2.  RE: Clearpass http Auth Intune attributes
    Posted Feb 13, 2025 04:35 AM
    Please check the IP address that's assigned to your extension, if that's 172.17.0.2.
    But probably the real issue is in the %{Certificate:Subject-AltName-URI}. Do you have an EAP-TLS (or TEAP) authentication, where in the client certificate SAN-URL you have the Intune device ID?
    Check in Access Tracker / Input / Computed Attributes if you have the Subject-AltName-URI there; then check if the (Intune) DeviceId is there either as a single plain field similar toe the Subject-AltName-DNS in the screenshot below, or if you are on the most recent Intune extension version that there is in the Subject-AltName-URI the "DeviceId:<deviceid-uuid>" also like the following screenshot:
    The error that you see suggests that there is no SAN-URI at all in the client certificate, or you don't even use EAP-TLS/TEAP with client certificates.
  • 3.  RE: Clearpass http Auth Intune attributes
    Posted Feb 13, 2025 04:53 AM
    I am using EAP-TLS and the  Subject-AltName-URI is showing.
    in the URI it could be displaying the AAD_Device_ID and not the DeviceID
    Should this field be showing the DeviceID in the same format you have above?
  • 4.  RE: Clearpass http Auth Intune attributes
    Posted Feb 13, 2025 11:09 AM
    Did you follow the instructions from https://arubanetworking.hpe.com/techdocs/NAC/clearpass/integrations/unified-endpoint-management/intune/ ?  Specifically the part about strong mapping?
    Carson Hulcher, ACEX#110
  • 5.  RE: Clearpass http Auth Intune attributes
    Posted Feb 13, 2025 02:15 PM
    There are two device IDs that can be configured from Intune: {DeviceId} which is the Intune Device ID, and {AAD_Device_ID}, which is the Entra ID Device ID. Both are different, and for Intune queries you need the {DeviceId}; for Entra ID queries you would need the {AAD_Device_ID}. For most flexibility, make sure both are available so you can check Intune and Entra ID where needed.
    The documentation that Carson referred to has a lot of information on how to configure this.
