  • 1.  Clearpass https certificate SAN
    Posted Feb 05, 2016 08:48 AM
    i have the following on my Aruba controller :
    login-page "https://192.168.203.30/guest/guest.php"
    Whenever a user connects his browser gets a warning in IE or Chrome because the Clearpass server https certificate has CN=wifi-003 instead of 192.168.203.30.  It is possible to continue, but not a nice setup.
    The logical solution would be to create a selfsigned certificate, register the name in dns.
    Here comes the problem...  The certificate signing server is in a domain, which is not externally available.  So let's assume it's in domain contosa.com.  This domain is only available internal.
    So i could create a selfsigned certificate wifi-003.contosa.com, change the login-page to :
    login-page "https://wifi-003.contosa.com/guest/guest.php"
    but nobody could resolve it since the guest network only has Google's dns servers for resolving.
    I do not have any detail what a browser verifies, but i assume creating a selfsigned certificate on the certificate server in domain contosa.com with CN=wifi-003.contosanew.com also would not work?
    I noticed however the SAN option in the CSR is available in Clearpass.  Can this one be used to specify a FQDN which we do own?  And then specify that FQDN in the login-page?
  • 2.  RE: Clearpass https certificate SAN
    Posted Feb 05, 2016 09:39 AM
    Pnobels,
    There are two requirements for the message not to show up.:
    1 - The Client Trusts the Certificate or the CA that issued the certificate
    2 - The SAN matches the redirect address
    For #1, you need a public certificate.  For #2, you need a cert with a proper SAN fqdn.  Unfortunately, public CAs only issue public certificates for domains that you own publicly, so you must own the domain to get a public fqdn certificate for it.  Please see "CA changes for Internal FQDN’s and RFC1918" in the
    Certificates 101 Technote here https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=19184
  • 3.  RE: Clearpass https certificate SAN
    Posted Feb 05, 2016 10:57 AM
    For the DNS issue, you have two options:
    - Add ClearPass IP to public DNS
    - Utilize the DNS proxy feature of your upstream router
  • 4.  RE: Clearpass https certificate SAN
    Posted Dec 25, 2018 07:34 AM
    Hi Tim,
    in addition to :
    we can setup 2 DNS server in guest users DHCP pool with
    DNS1: public DNS (like 8.8.8.8)
    DNS2: private DNS (contain CP hostname IP resolution entry).
    it should work correctly ? any caveat ?
