Cedric, can you please open a TAC Support case for this? You are not the first to report this, and I tried multiple times to replicate the same in my lab but could not replicate. It just works here if I generate CSR, get it signed (through Windows CA, not public CA, but should not make a difference), and import in ClearPass.
There is a change though in ClearPass 6.11 that the private key for a CSR is not retained for a long period, but it should be in the range of a week or so. If it took a really long time, you could try again and then make sure that you import the certificate faster after generating the CSR.
Because it's not the first time I hear this, it would be good that Aruba Support has a look at it so when the root cause is found it can be fixed in the product.
Original Message:
Sent: Feb 21, 2023 09:19 AM
Subject: Clearpass HTTPS ECC certificate import issues
Hi!
Anyone having trouble in 6.11 to import certificates? I did it before in 6.10, but now it is such a hassle.
I created an CSR in Clearpass, passed that along to my provider Xolphin, and they returned with root/intermediate (Sectigo) and a CRT file.
I imported/enabled the root/intermediate, and tried to import my CRT but then it asks a private key... But it said upon creating CSR that the private key is stored in Clearpass?
Afterwards, I tried by using OpenSSL where I created the private key as .key file and CSR, and when importing CRT & KEY file it says "Private Key Type not allowed for this particular Server Certificate".. Also that private key password, I didn't choose one in openssl.
Anyone an idea what best is to do?
Thanks!
Cedric
