When there is a spike in memory usage. The swap increases, it would eventually go down after some time, but yeah it is annoying to see it. The best way to track if the spike in the memory is normal, is to have a snmp server, monitoring clearpass. If you have Airwave, you could add clearpass to it and configure trigger alerts for memory, cpu or disk upto some threshold. Then, we could check the logs to see for that timestamp, when the alert generated to understand, why the high spike on memory, to troubleshoot accordingly.
we can directly configure triggers on Clearpass too, but as of today, we dont have an option to configure alerts for memory, we have it for CPU and Disk usage only. This link below helps in setting alerts for them, on clearpass
https://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Configure-CPPM-to-monitor-CPU-load-average-and-Disk-space/ta-p/290834
I would recommend you to open a TAC case, so they can collect the logs and check the memory usage to make sure, if everything is good.
