Hi
I don't know if there is an option to clear the request manually.
But I have seen other persons having issues on 6.11.
https://community.arubanetworks.com/discussion/clearpass-https-ecc-certificate-import-issues#bmbac301c5-82f4-43e1-b73f-ea4d47cd0c7c
I have not run into issues when requesting certificates for 6.11.
Best Regards
Jonas Hammarbäck
MVP 2023, ACCX #1335, ACMP, ACDP, ACP-Network Security, ACEP, ACSA
Aranya AB
Original Message:
Sent: Feb 22, 2023 06:26 AM
Subject: Clearpass import certificate failed
Hi.
Im doing it by the book, using the use private saved keys, just made the request today 1 hour ago, is there a way to cleanup the saved keys manuel? the value is standard 15 days in 6.11.1.25xxxx
mayby the request is hanging, so if i can cleanup the requests and make a new one
mojo
Original Message:
Sent: Feb 22, 2023 06:22 AM
Hi Morten
Have you selected the option "Upload certificate and use saved private key"?
How many days is it since you created the CSR? If it's longer time than the clean up intervall for information stored on the disk the CSR will be deleted. By default 7 days.
In ClearPass 6.11 there are a new option to set a different value for CSR files, found under Cluster Wide parameters\Cleanup Intervalls.
Best Regards
Jonas Hammarbäck
Aranya AB
Original Message:
Sent: Feb 22, 2023 05:43 AM
hi, i'm about to import a radius server certificate.
Made af certificate request and got it signed with a local pki ca as a webserver template.
When i import it back in clearpass i get a "private key file must be specified" even when i made a request in the clearpass server.
Any ideers?
Morten
