  • 1.  Clearpass in Azure with multi-tenancy
    Posted Jun 23, 2021 10:21 PM
    Is it possible to run a single instance of Clearpass in Azure with multiple Azure tenants?
    If so, is this done by adding the necessary JSON config below the first entry
    John Wilkens
  • 2.  RE: Clearpass in Azure with multi-tenancy
    Posted Jun 24, 2021 04:47 AM
    This is exactly the same as any ClearPass environment: Officially you cannot do multi-tenant. This is because there is only one database for all the tenants – hence there is a potential for a tenant to learn information of another tenant's environment.
    You can create a pseudo multi-tenant environment: This is reliant on using CPG Operator to control what they can view active sessions, disconnect/change-role of an active session, create/view/delete user accounts, create/view/delete devices. This is achieve by creating Operator Logins that restricts a Tenant to seeing his/her related users/devices/sessions.
    However, this is all predicated on the basis that there is no overlap of NAS IP addresses between Tenants.
    Attached is an old presentation I put together covering this type of approach.
    Regards Derin
    Principle ClearPass Engineer
    Blue Sky Systems Limited
    Tel: 03300 101 550
    DDI: 03300 101 474
    Mobile: 07749 100 180
    Email: derin.mellor@blueskysystems.com
    Web: www.blueskysystems.co.uk
    Registered in England No: 8856125
    Registered Office: Dorset House, Regent Park, 297-299 Kingston Road, Leatherhead, KT22 7PL
  • 3.  RE: Clearpass in Azure with multi-tenancy
    Posted Jun 25, 2021 04:23 AM
    Here's the presentation
    Derin Mellor
    Attachment(s)
    pptx
    Pseudo Multi-Tenant.pptx   3.58 MB 1 version
