Clearpass Interfaces (Data & Management) for Azure Deployment
  • 1.  Clearpass Interfaces (Data & Management) for Azure Deployment
    Posted Jul 31, 2024 03:08 PM
    The Aruba Clearpass harding documentation indicates the following;
    "ClearPass utilizes separate management and data interfaces, and provides the ability to restrict access to the management interface to just authorized end stations."
    Is this the case for a specific implementation in Azure? Are there any restrictions in ClearPass or Azure for deployment utilizing multiple interfaces?
    Is there a requirement to deploy Azure Clearpass with a single interface - mixing the data and management traffic planes?
  • 2.  RE: Clearpass Interfaces (Data & Management) for Azure Deployment
    Posted Jul 31, 2024 03:45 PM
    The data port isn't supported in cloud deployments, only the management port is available.
    Carson Hulcher, ACEX#110
  • 3.  RE: Clearpass Interfaces (Data & Management) for Azure Deployment
    Posted Aug 01, 2024 09:39 AM
    You can still set the ACLs to allow only specific client subnets (or exclude specific subnets) for access to the Policy Manager Web interface. That is done under Server Manager - Server Configuration - <your server> - Network - Application Access Control.
    Unsure how/why the data-management port ended up in that guide, as on premises you can connect through either interface to the CPPM Management, so I would not recommend using data-management ports for security reasons, just for some corner-case routing challenges. But, as mentioned in Azure you don't even have the option to use data interfaces, so it's even more simple.
