  • 1.  Clearpass Interfaces (Data & Management) for Azure Deployment
    Posted Jul 31, 2024 03:08 PM
    The Aruba Clearpass harding documentation indicates the following;
    "ClearPass utilizes separate management and data interfaces, and provides the ability to restrict access to the management interface to just authorized end stations."
    Is this the case for a specific implementation in Azure? Are there any restrictions in ClearPass or Azure for deployment utilizing multiple interfaces?
    Is there a requirement to deploy Azure Clearpass with a single interface - mixing the data and management traffic planes?
  • 2.  RE: Clearpass Interfaces (Data & Management) for Azure Deployment
    Posted Jul 31, 2024 03:45 PM
    The data port isn't supported in cloud deployments, only the management port is available.
    Carson Hulcher, ACEX#110
  • 3.  RE: Clearpass Interfaces (Data & Management) for Azure Deployment
    Posted Sep 19, 2024 12:27 PM
    Sorry to hijack this thread, but I'm wondering if you might be able to explain why the CPPM 6.11.x Azure deployment guide specifically instructs the addition of a 2nd network interface (data port) if it is not supported?
    I'm referring to this guide here:
    https://www.arubanetworks.com/techdocs/ClearPass/6.11/Installation-Guide/Default.htm#Cloud-Azure/CD-AZ-cppm-in-azure.htm?TocPath=Cloud%2520Deployments%253A%2520Microsoft%2520Azure%2520Cloud%2520Service%257C_____2
    Under the Networking header, it states:
    Once the VA is created, you must log in to the Azure portal and create a second interface for the VA.
    This links to a lower section on the page giving instructions for doing so in the Azure portal:
    https://www.arubanetworks.com/techdocs/ClearPass/6.11/Installation-Guide/Default.htm#Cloud-Azure/CD-AZ-cppm-in-azure.htm#Adding
    I'm asking mainly because I added a 2nd interface to our Azure VAs because of this guide, so I'm hoping there are no adverse effects.
  • 4.  RE: Clearpass Interfaces (Data & Management) for Azure Deployment
    Posted Sep 19, 2024 12:36 PM
    ClearPass expects the second interface to be present even when the underlying environment doesn't necessarily support the functionality.
  • 5.  RE: Clearpass Interfaces (Data & Management) for Azure Deployment
    Posted Sep 19, 2024 12:42 PM
    Ah, that makes sense, thanks!
  • 6.  RE: Clearpass Interfaces (Data & Management) for Azure Deployment
    Posted Aug 01, 2024 09:39 AM
    Edited by Herman Robers Aug 01, 2024 09:40 AM
    You can still set the ACLs to allow only specific client subnets (or exclude specific subnets) for access to the Policy Manager Web interface. That is done under Server Manager - Server Configuration - <your server> - Network - Application Access Control.
    Unsure how/why the data-management port ended up in that guide, as on premises you can connect through either interface to the CPPM Management, so I would not recommend using data-management ports for security reasons, just for some corner-case routing challenges. But, as mentioned in Azure you don't even have the option to use data interfaces, so it's even more simple.
